Author Topic: expected efficiency to calculate RMF value  (Read 1662 times)
Offline karmaxTopic starter
« on: February 05, 2008, 07:57:58 AM »
i came across this RMF today on the site. i m designing an autonomous robot which is quite heavy. plz temme wat shud i put in expected efficiency column to calculate RMF VALUE.
Does it depend on the quality of the motor??
Re: expected efficiency to calculate RMF value
« Reply #1 on: February 05, 2008, 08:29:21 AM »
The only way to know efficiency accurately is to build the entire robot and measure it . . . so since that isn't possible, you have to estimate based on basic principles.
For example, typical gears have 90% efficiency. If your robot has high friction on the ground, thats another loss. Got tracks? Another efficiency loss.
If you have high precision mechanical components, and your robot is well designed, you may get 85% efficiency. But if you hand make everything, expect more like 70% efficiency . . .
Nope, because this is factored in already on the motor output specs. The torque they give on the datasheet should be what comes out the motor.
Last post October 30, 2008, 10:32:37 PM
Last post October 11, 2010, 06:44:30 PM
Last post May 27, 2011, 09:08:57 PM
by nfwill
Last post January 07, 2013, 08:23:01 PM
by jwatte
