Author Topic: Gumstix FPU query  (Read 1717 times)
Offline neo01124Topic starter
Gumstix FPU query
« on: February 06, 2008, 03:31:05 PM »
I am planning to use a gumstix+gpsstix combo for an autonomous robot and read that it does not have an FPU
I want to know what consequences it has i.e. how does it restrict my programming abilities ? And what kind of stuff will i not be able to do?
There will also be other sensors like Ultrasonic and accelerometer attached to it.....
Moreover i read that an FPU can also be implemented in software, exactly what does that mean?
Offline hgordon
  • Helpful? 7
Re: Gumstix FPU query
« Reply #1 on: February 06, 2008, 05:56:21 PM »
That means they are using software emulation, not actual FPU hardware, so it will be SLOW.
Surveyor Corporation
  www.surveyor.com
Offline paulstreats
« Reply #2 on: February 06, 2008, 06:24:53 PM »
maybe you can interface an hardware fpu to the gumstix, though i dont know wether the time difference loss would be any better. I suppose it depends on how many  decimals you were needing to calculate to
Offline Commanderbob
  • Embeddedmicro.com
« Reply #3 on: February 07, 2008, 10:14:22 PM »
Not really. The Gumstix are Linux computers. I use the Verdex XL6P, Robostix, and netwifimicroSD-FCC cards for my robot. The XL6P runs at 600MHz (the rest are 400MHz) not 40MHz like a fast PIC. It is also a 32bit processor not an 8bit like PICs or other common micro controllers. Yes, software FPU is slower but I have not noticed any problems with speed.
You can do A LOT more with a Gumstix. For a robot you NEED a robostix. It is a Atmega128 running at 16MHz that does the ADC, PWM, and IO. You talk to it over I2C with the Gumstix. See what I have done so far at: http://coilgunpower.com/gumstix/cgtank.asp
Good luck,
Justin
