Author Topic: two wheel balancing robot  (Read 2573 times)
Offline Sanjay123Topic starter
« on: February 11, 2008, 01:37:42 PM »
Hi ,
I am building a robot which is balanced on two wheel , i want suggestion if i need to use gyroscope ?   i plan to balance it on wheel with the entire weight evenly placed . What kinda wheels , and motors should i go for ? i plan to have 3 3/4 " diameter wheel . Can any one give me some suggestion.
Sanjay
Offline Trumpkin
Re: two wheel balancing robot
« Reply #1 on: February 11, 2008, 03:55:03 PM »
you could use a gyroscope but you could also use a Sharp IR sensor pointed towards the ground. you could then measure the distance from the ground. here's how it would work with Sharp IR, when you tilt backwards the sensor would be farther from the ground and if you tilted forwards the sensor would be closer to the ground. assuming that the sensor is on the front of your robot.
gyroscopic sensor could be $60+ while Sharp IR sensors cost $10.
Robots are awesome!
« Reply #2 on: February 12, 2008, 11:25:18 AM »
I am trying out a structure which is stable when not acted upon by force , I have seen robots that are stable dynamically . Any idea on this one ?
Offline Trumpkin
« Reply #3 on: February 12, 2008, 12:13:21 PM »
i don't know but I think you should have digital servos instead of analog, digital is more accurate than analog.
Robots are awesome!
« Reply #4 on: February 16, 2008, 06:42:56 PM »
search this forum for 'segway' and 'balance'
this question has been asked/discussed a billion times :P
Last post February 23, 2012, 04:16:38 AM
by newInRobotics
Last post March 13, 2011, 03:04:05 PM
by newInRobotics
Last post October 14, 2010, 07:03:46 PM
by chuong_bk
Last post October 23, 2011, 10:18:32 AM
