Author Topic: error on build - a2d.h - line 140 - help!  (Read 5333 times)
Offline silo_xtremeTopic starter
  • I really love robots, they keep me awake at night.
« on: February 12, 2008, 06:18:17 PM »
Hi all,
In a2d.h the compiler has a problem with line 140
//! return TRUE if conversion is complete
u08 a2dIsComplete(void);
Any ideas?
Offline paulstreats
  • Helpful? 20
Re: error on build - a2d.h - line 140 - help!
« Reply #1 on: February 12, 2008, 06:20:58 PM »
probably
u08 = a2dIsComplete(void);
« Reply #2 on: February 12, 2008, 06:53:31 PM »
not the case.  it works with the makefile that comes with the $50 robot.  It's a return type, i just want to use a different chip....
« Reply #3 on: February 12, 2008, 10:01:22 PM »
u08 means int, or 8 bit int
use this to change from $50 ATmega8 code to code for your microcontroller:
http://www.societyofrobots.com/step_by_step_atmega168_swapout.shtml
« Reply #4 on: February 12, 2008, 10:25:45 PM »
admin,
where / what library is u08 defined?
« Reply #5 on: February 12, 2008, 10:35:29 PM »
Its part of the C language, as defined by gnc :P
doing this:
is the same as this:
int a2dIsComplete(void);
« Reply #6 on: February 12, 2008, 10:38:14 PM »
admin,
thanks!  I guess the silly AVR Studio 4 doesn't know u08 ?
« Reply #7 on: February 12, 2008, 10:41:27 PM »
Which microcontroller are you using?
Did you change all of the code to reflect that microcontroller?
What is the exact error you are getting?
« Reply #8 on: February 12, 2008, 10:46:18 PM »
I've changed all the ports and timing files
I'm using the Atmega 2560 ...
I have the following error:
C:\..\..\Program Files\AVRlib/a2d.h:141: error: expected '=', ',', ';', 'asm' or '__attribute__' before 'a2dIsComplete'
It compiles with your makefile , just not with settings in the AVR Studio ....
I wanted to try to compile it in the studio, because I'm not able to get debug values back over the JTAG interface properly....
« Reply #9 on: February 12, 2008, 11:43:57 PM »
Admin,
After searching I found this:
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=58058
Was this you?  ;)   If so, did you ever get that new .h file working?
« Reply #10 on: February 15, 2008, 04:34:54 PM »
hmm .... really no more ideas?
« Reply #11 on: February 17, 2008, 10:13:31 AM »
yeap, that avrfreaks post basically highlights the solution
« Reply #12 on: February 17, 2008, 10:17:38 AM »
excellent.  Oh, after updating AVR Studio and putting the "globals.h" header before the others - it finally works no problem.
Thanks again for all your help!
Last post October 26, 2007, 08:19:02 PM
by HDL_CinC_Dragon
Last post June 04, 2008, 11:12:10 PM
by superchiku
Last post June 25, 2009, 07:37:31 PM
by justkilintyme
Last post June 15, 2011, 02:47:54 PM
by adanvasco
