Author Topic: Strange code problem  (Read 1456 times)
Offline gamefreakTopic starter
  • Robo-Enthusiast
« on: February 14, 2008, 08:06:09 PM »
Alright, while working on a demo for my project I found something strange, all of the servos are hooked up the same way, number 4 and 5 always rotate the same direction and they are modified, numbers 1 through 3 all rotate clockwise then reset, but number 0 goes the opposite direction, the other 3 servos are hitec, while the first one is from parallax, is this what the problem is?
int i;
for(i=0;i<150;i++)
PORT_ON(PORTD,7);
delay_cycles(25);
PORT_OFF(PORTD,7);
delay_cycles(200);
while(1)
for(i=0;i<25;i++)
PORT_ON(PORTD, 0);
delay_cycles(20);
PORT_OFF(PORTD, 0);//keep off
delay_cycles(200);
PORT_ON(PORTD, 1);
delay_cycles(20);
PORT_OFF(PORTD, 1);//keep off
delay_cycles(200);
PORT_ON(PORTD, 2);
delay_cycles(20);
PORT_OFF(PORTD, 2);//keep off
delay_cycles(200);
PORT_ON(PORTD, 3);
delay_cycles(20);
PORT_OFF(PORTD, 3);//keep off
delay_cycles(200);
PORT_ON(PORTD, 4);
delay_cycles(20);
PORT_OFF(PORTD, 4);//keep off
delay_cycles(200);
PORT_ON(PORTD, 5);
delay_cycles(20);
PORT_OFF(PORTD, 5);//keep off
delay_cycles(200);
delay_cycles(2000);
for(i=0;i<25;i++)
PORT_ON(PORTD, 0);
delay_cycles(25);
delay_cycles(200);
PORT_ON(PORTD, 1);
delay_cycles(25);
delay_cycles(200);
PORT_ON(PORTD, 2);
delay_cycles(25);
delay_cycles(200);
PORT_ON(PORTD, 3);
delay_cycles(25);
delay_cycles(200);
PORT_ON(PORTD, 4);
delay_cycles(25);
delay_cycles(200);
PORT_ON(PORTD, 5);
delay_cycles(25);
delay_cycles(200);
delay_cycles(2000);
for(i=0;i<25;i++)
PORT_ON(PORTD, 0);
delay_cycles(30);
delay_cycles(200);
PORT_ON(PORTD, 1);
delay_cycles(30);
delay_cycles(200);
PORT_ON(PORTD, 2);
delay_cycles(30);
delay_cycles(200);
PORT_ON(PORTD, 3);
delay_cycles(30);
delay_cycles(200);
PORT_ON(PORTD, 4);
delay_cycles(30);
delay_cycles(200);
PORT_ON(PORTD, 5);
delay_cycles(30);
delay_cycles(200);
delay_cycles(2000);
for(i=0;i<25;i++)
PORT_ON(PORTD, 0);
delay_cycles(35);
delay_cycles(200);
PORT_ON(PORTD, 1);
delay_cycles(35);
delay_cycles(200);
PORT_ON(PORTD, 2);
delay_cycles(35);
delay_cycles(200);
PORT_ON(PORTD, 3);
delay_cycles(35);
delay_cycles(200);
PORT_ON(PORTD, 4);
delay_cycles(35);
delay_cycles(200);
PORT_ON(PORTD, 5);
delay_cycles(35);
delay_cycles(200);
delay_cycles(2000);
for(i=0;i<25;i++)
PORT_ON(PORTD, 0);
delay_cycles(40);
delay_cycles(200);
PORT_ON(PORTD, 1);
delay_cycles(40);
delay_cycles(200);
PORT_ON(PORTD, 2);
delay_cycles(40);
delay_cycles(200);
PORT_ON(PORTD, 3);
delay_cycles(40);
delay_cycles(200);
PORT_ON(PORTD, 4);
delay_cycles(40);
delay_cycles(200);
PORT_ON(PORTD, 5);
delay_cycles(40);
delay_cycles(200);
delay_cycles(2000);
/* Servo Test Code
i=250;
while(i>0)
servo_left(40);
i--;
i=250;
while(i>0)
servo_left(24);
i--;
//rprintf("Initialization Complete\r\n");
//output message to serial (use hyperterminal)
//print("Hello, World! Read My Analog: %u\r\n", sensor_0);
//delay_cycles(500);//a small delay to prevent crazy oscillations
/*********ADD YOUR CODE ABOVE THIS LINE **********/
return 0;
« Last Edit: February 15, 2008, 06:49:11 AM by gamefreak »
Re: Strange code problem
« Reply #1 on: February 15, 2008, 12:16:42 PM »
does the parallax servo work fine if you change the code to go the other way?
  • Robo-Enthusiast
« Reply #2 on: February 15, 2008, 07:19:10 PM »
all of the servos go to the end, then rotate back to the starting delay, although the modified servos only rotate in a single direction, the potentiometer is probably off and I dont have an oscilloscope, are there any cheap ones?
« Reply #3 on: February 16, 2008, 04:40:41 PM »
You use a multimeter to measure potentiometers, not oscilloscope ;)
Anyway, assume that the parallax servos require a different square wave to operate. Just try changing the frequency and see what happens.
As for a cheaper servo, the HS-311 is always $8.99
Last post December 06, 2006, 10:04:26 PM
by dunk
Last post March 16, 2008, 01:06:15 AM
by superchiku
Last post March 25, 2009, 12:32:24 AM
Last post July 24, 2009, 09:59:04 PM
