Author Topic: a2dConvert8bit returning wrong values  (Read 2104 times)
Offline silo_xtremeTopic starter
  • I really love robots, they keep me awake at night.
« on: February 16, 2008, 12:53:17 PM »
Hi all,
My a2dConvert8bit function should be giving me a value of 30 according to the output voltage and sharp IR documentation.
The function is actually giving me 120, any ideas?
Mike
« Last Edit: February 16, 2008, 04:31:14 PM by silo_xtreme »
Re: a2dConvert8bit returning wrong values
« Reply #1 on: February 16, 2008, 11:40:42 PM »
is it giving you the same value all the time, regardless of distance?
also, did you set up the analog ports and inputs properly?
« Reply #2 on: February 17, 2008, 09:50:06 AM »
Ok, I've been checking this.
Looks like i'm expecting to get 30 (aka 30cm) because the volt meter says my Sharp IR is outputting 2V.  (I measured it).
However, when I get the value back from a2dConvert8bit , it's ~ 120 (it does change) +/- 2
Does this have something to do with my Reference?  I'm a little confused.   ???
Re: a2dConvert8bit returning wrong values?????
« Reply #3 on: February 17, 2008, 10:53:42 AM »
Still thinking about this one....
Perhaps what I am getting back is my 2V as a number between 0-255 ?  Even with that assumption, i'm not sure I'm getting the right values.....
am i missing an equation or table lookup for the Sharp IR?
« Reply #4 on: February 17, 2008, 11:44:23 AM »
Hi again,
My N00b brain is still learning, and I read this article:
http://en.wikipedia.org/wiki/Analog-to-digital_converter
Now, I realized that the SOR code for the $50 robot does "obstacle detection";  silly me was thinking that I should be getting back values for distance.
If I wanted distance values I would probably make a look up table and compute it.  right?  ;)
« Reply #5 on: February 18, 2008, 09:37:15 AM »
yeap :P
(airman00 asked the exact same questions I would have)
Last post July 18, 2007, 04:55:36 AM
Last post January 14, 2008, 02:09:57 PM
by rox2007
Last post January 22, 2009, 09:36:37 PM
Last post January 12, 2013, 03:40:53 PM
by jwatte
