Author Topic: Switch Polarity IC?  (Read 4193 times)
Offline silo_xtremeTopic starter
  • I really love robots, they keep me awake at night.
Switch Polarity IC?
« on: February 20, 2008, 03:23:23 PM »
I was just wondering if someone knew of an IC (or some other solution) that would switch the polarity on my motor wires.
For example,  I just want to modify a speed controller and see if I could put an IC between the speed controller and my motor in order to get that "reverse" capability for a "low cost"  ::)
Offline ed1380
Re: Switch Polarity IC?
« Reply #1 on: February 20, 2008, 03:27:02 PM »
if you want to reverse the direction of the motor and it's not a brushless motor. every motor driver should be able to do that. some use a high or low pin others use serial communication.
with no motor driver just theoretically if the mcu could output enough power for the motor just make one pin high and another low. and reverse that for reverse
« Reply #2 on: February 20, 2008, 03:29:59 PM »
I think I forget to mention, it's a 12V brushed motor.
Now whatcha got for me?  :P
Offline ed1380
« Reply #3 on: February 21, 2008, 02:38:41 PM »
no double posting please.
read up on motor drivers, h-bridges.
http://www.societyofrobots.com/schematics_h-bridgedes.shtml
