Author Topic: code Q's  (Read 1456 times)
Offline ed1380Topic starter
code Q's
« on: February 21, 2008, 05:27:11 PM »
since i finally got my programmer working i'm beginning to have perplexing problems with the code part of things.
heres the code I'm working with now. just basically the $50 robot code.
with it I'm able to get the led to light up for one second. good. what's what i want except why isnt it looping and blinking?
"return 1" and "return 0" doesnt make a diference. "loop" causes build errors
//SoR Include
#include "SoR_Utils.h" //includes all the technical stuff
int main(void)
configure_ports(); // configure which ports are analog, digital, etc.
/*********ADD YOUR CODE BELOW THIS LINE **********/
PORT_OFF(PORTD, 4); //turns led on
delay_cycles(23000); // one second delay
PORT_ON(PORTD, 4); //turns led off
/*********ADD YOUR CODE ABOVE THIS LINE **********/
return 0;
« Last Edit: February 21, 2008, 05:32:12 PM by ed1380 »
Offline frank26080115
Re: code Q's
« Reply #1 on: February 21, 2008, 05:42:00 PM »
you are not telling it to loop so why would it loop?
loops are supposed to be done by using
while(1){
//code in here
« Last Edit: February 21, 2008, 05:42:58 PM by frank26080115 »
Offline paulstreats
  • Helpful? 20
Re: code Q's
« Reply #2 on: February 21, 2008, 05:45:27 PM »
put it inside a while loop
while(1){
//code to be looped here
the return doesnt work because its used for a different purpose (returning a value - not returning to a point in the program)
Re: code Q's
« Reply #3 on: February 21, 2008, 07:57:16 PM »
thanks.
took some fiddling around but it worked
Re: code Q's
« Reply #4 on: February 25, 2008, 10:40:23 PM »
well i got more problems.
I'm finally able to get the wanted pins to work. kinda. it goes. 0,1,2,3,3,2,1,0,0,0,0,0,0,0,etc
i used this to get it
up=0
down=3
if(up<=3)
PORT_ON(PORTD, up);
delay_cycles(8000);
PORT_OFF(PORTD, up++);
delay_cycles(8000);
else
PORT_ON(PORTD, down);
delay_cycles(8000);
PORT_OFF(PORTD, down--);
delay_cycles(8000);
fine that'll do, but i  want to do it with the FOR loop. but i cant get it to go past 0,0,0,0,0
EDIT:
BOOYA got it to work. guess all i needed was some sleep
while(1)
for(int up = 0; up<=3; up++)
PORT_ON(PORTD, up);
delay_cycles(1000);
PORT_OFF(PORTD, up);
delay_cycles(1000);
for(int down = 3; down<=3;down--)
delay_cycles(1000);
PORT_OFF(PORTD, down);
delay_cycles(1000);
if(down == 0)
break;
« Last Edit: February 26, 2008, 04:38:28 PM by ed1380 »
Last post November 26, 2007, 07:46:27 PM
by DomoArigato
Last post June 08, 2008, 05:34:59 PM
by Parth
Last post August 12, 2008, 01:20:02 AM
by vidam
Last post December 05, 2009, 03:57:55 AM
by ozbot
