Author Topic: FIFO Tx Buffer, Lost Chars  (Read 1554 times)
Offline frank26080115Topic starter
« on: February 23, 2008, 08:09:12 PM »
Here's the story, I've created my own FIFO buffer for Tx-ing data with UART, this makes sending a long string super efficent and fast.
But when I try sending out "Test12345\n\r", hyperterminal only shows "Tes134\n"
01234567890123456789012345678901234567890123456789
gives
012467913468913568013578023579
lets look for a pattern:
012 4 67 9 1 34 6 89 1 3 56 8 01 3 5 78 0 23 5 7 9
weird huh?, doesn't seem to be a pattern, but the \n is still detected, but not the \r
also it's the exact same missing characters every time.
I've checked my code over and over again, no idea why it's happening. baud rate is correct, 115200 baud. the buffer size is 100. shouldn't be overflowing, there is nothing else going on the microcontroller. i added a delay in between transmission but it didn't help. all global variables are declared volatile too and it didn't help. AVRstudio's simulator is usesless since it doesn't trigger interrupts
why the hell isn't it working? attached is all the code.
ok i forgot to enable interrupts... but now i have another weird problem
it's sending the first char, but the next few bytes are sent as binary 0... then it goes back to normal but still missing characters
Fixed, lesson learned: use SIG_USART_TRANS instead of SIG_USART_DATA. works like a charm now
« Last Edit: February 23, 2008, 08:36:38 PM by frank26080115 »
Last post February 17, 2009, 11:10:14 AM
by superchiku
Last post October 12, 2011, 01:14:28 PM
by Gertlex
Last post April 16, 2012, 02:03:45 PM
by Webbot
Last post July 18, 2012, 09:23:54 AM
by totalis
