Author Topic: manual controlled mill  (Read 4069 times)
Offline BANETopic starter
  • E=roboticsC^2
« on: February 23, 2008, 09:20:03 PM »
hello, i need some help and advise on making a mill controller.  I'm using three 12vdc motors (small mill) and want to control them using a joystick I got out of a airplane controller (two potentiometers, X & Y).  Everything is going to analog and farley simple.  I want to have to motors speeds vary on how far the joy is pushed.  I'm guessing that i would have a series of transistors and diodes or H-bridge.  I can make to pots control the motors in only one direction.  I need help on how to make it where i get control both directions and proportional speeds.
check out pics ;)
bane
Re: manual controlled mill
« Reply #1 on: February 23, 2008, 09:48:25 PM »
well with a microcontroller you would take an ADC of the joystick pots, and generate a PWM to the H bridge based on the resistance of the pots
Like if the ADC was 122 ( of an 8 bit conversion)  thats halfway so you would give a PWM of 50%
  • E=roboticsC^2
« Reply #2 on: February 23, 2008, 10:04:49 PM »
I'm trying to build something simular to this, only use my joy instead.
http://www.hobbyengineering.com/CatEKMOT.html
any idea what the schematics might look like?
bane
« Reply #3 on: February 23, 2008, 10:07:00 PM »
bane
http://info.hobbyengineering.com/specs/DIY-k166.pdf
datasheets man! Its all in there
  • E=roboticsC^2
« Reply #4 on: February 23, 2008, 10:20:02 PM »
ha, just as you posted that i just came back to say i found it! :D. only it was a different website
thanks!
bane
« Last Edit: February 23, 2008, 10:20:48 PM by BANE »
  • E=roboticsC^2
« Reply #5 on: February 23, 2008, 11:07:27 PM »
You know the more I look into this, it would be cheaper and easier to use my microcontroller and a H-bridge  :D
bane
« Reply #6 on: February 23, 2008, 11:17:33 PM »
bane
hmmm that sounds familiar  ;)
well with a microcontroller you would take an ADC of the joystick pots, and generate a PWM to the H bridge based on the resistance of the \
and it would be cheaper
Offline ed1380
« Reply #7 on: February 23, 2008, 11:43:24 PM »
2 servo's man. replace the pots of the servo with the joystick and solder your motors on instead of the old ones. you still might need to use transistors/mosfets to beef up the controller board
« Reply #8 on: February 24, 2008, 12:08:01 AM »
sounds good .... in theory
the pots would have to match  and there might be other problems that will pop into my head tomorrow
good night US east coast!  ;)
  • E=roboticsC^2
« Reply #9 on: February 24, 2008, 12:03:32 PM »
So if that would work, i would have to modify the servo to handle 9.6v or does it matter since im replacing the motors?
Another thing, I would have to generate a pulse simular to what a microcontroller would do only with out it.
bane
« Reply #10 on: February 24, 2008, 12:10:07 PM »
the circuit in the servo can only hold up to 7.2V ( really supposed to be 6V)
  • E=roboticsC^2
« Reply #11 on: February 24, 2008, 01:09:43 PM »
I know, but can you modify it?
bane
Offline paulstreats
  • Helpful? 20
« Reply #12 on: February 24, 2008, 01:15:26 PM »
I would stick to using motors personally, ideally stepper motors. You would need a controller mcu to use it properly but it would mean that you can work on making it computer controlled at a later date without having to setup encoder etc..
  • E=roboticsC^2
« Reply #13 on: February 24, 2008, 01:35:20 PM »
I have three stepping motors I got from a print/scanner.  I guess its worth a shot, however, the motors that i got only have 4 pins, most of the stepping controllers that i've seen require at least 5 pins.....  any ideas?   I have a microcontroller and if I could get three stepper controllers it wouldn't be to hard to make.  Just a thought, i have the BOT BOARD II w/ BASIC ATOM 28 pin, I could even control it using a PS2 controller...  sweet!
any suggestions where to get three cheap stepping motor controllers (4 pin)?
bane
Offline ed1380
« Reply #14 on: February 24, 2008, 04:07:24 PM »
those are bipolar motors.
Offline paulstreats
  • Helpful? 20
« Reply #15 on: February 24, 2008, 04:28:42 PM »
a lot of normal motor full-bridge ic's can control stepper motors. Also you can use darlington driver ic's or just h-bridge type set up with mosfets. Its better to build your own than buy an expensive driver
  • E=roboticsC^2
« Reply #16 on: February 26, 2008, 06:17:24 AM »
is this the type?
http://www.hobbyengineering.com/H1143.html
if so, they seem pretty cheap to me :D
But, no idea how the schematics would look. :-\
bane
  • E=roboticsC^2
« Reply #17 on: February 26, 2008, 06:23:22 AM »
i just found this.
http://www.electronicsinschools.org/page.php?ps=2&p=11
i still don't know how to set it up to control a bi-polar using microcontroller though.
bane
Offline paulstreats
  • Helpful? 20
« Reply #18 on: February 26, 2008, 07:08:22 AM »
the uln 2003 seem ideal. I'll see if i can find a diagram for using it with a stepper motor, i saw one last week.
You will probably need one of the darlington arrays for each stepper. They are easy to use with a microcontroller
  • E=roboticsC^2
« Reply #19 on: February 26, 2008, 05:10:17 PM »
Thanks, i would appreciate it :).   He is a pic i found google, i'm guessing i'd make something similar.
bane
« Reply #20 on: March 01, 2008, 10:26:48 PM »
I'd recommend using potentiometers with knobs instead of your joystick idea.
This way you can get much easier and more precise/repeatable control over the motion.
Easier to interface, too.
  • E=roboticsC^2
« Reply #21 on: March 02, 2008, 08:09:09 PM »
Well I was thinking that i would use the joy with a microcontroller to operate.  I would have the microcontroller control the H-bridges.  I don't know much on getting the microcontroller to take direct readings from a pot, but i know theres code for the PS2 joy.  Besides, i think it would be fun. :D
bane
« Reply #22 on: March 02, 2008, 08:13:56 PM »
it would be simple analog to digital conversion for the pot
  • E=roboticsC^2
« Reply #23 on: March 03, 2008, 05:27:39 PM »
but wouldn't that mean that I would have to get some kind of convertor of some sort = $$$$.    PS2 controller = $20.00
i have to amit, i dont know to much about this but it seems more logical to me :\
bane
« Reply #24 on: March 03, 2008, 08:07:11 PM »
microcontrollers have built in analog to digital ,no extra $$$ needed
Last post January 24, 2007, 08:09:22 AM
by Qubix
Last post August 22, 2008, 11:08:14 AM
Last post August 09, 2009, 06:02:01 PM
by Kirk
Last post September 13, 2011, 09:37:54 AM
by Supremacy
