Author Topic: OOPic R Voltage Regulator  (Read 1436 times)
Offline vivek9856Topic starter
« on: February 24, 2008, 02:45:46 PM »
I think I burnt out my Logic voltage regulator on my OOPic R. I plugged my battery in this morning, and nothing would happen. The EAC light on the board that usually came on is not on now. However, when I click the three built in buttons on the board, their respective LED's light up. When plugged into the serial port to program, the computer can no longer recognize that a board is present.
I checked the voltage b/t the middle pin and the left pin of the voltage regulator near the LCD pin / serial port, and its only reading about 2.85 volts now when the board is powered from a 9V battery.
What do I do now? How do I fix my board? Space is not an issue, so if necessary, I could wire another voltage regulator outside of the board.
I was thinking about getting a similar voltage regulator and simply replacing it on the board. Is this the same thing? http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=1737768&pa=1737768PS
Thanks!
Re: OOPic R Voltage Regulator
« Reply #1 on: February 27, 2008, 09:18:50 PM »
You are just using a normal 9V, right? I suspect that your 9V is now a dead battery, and that getting a new one should fix the problem.
Whats the voltage across the battery when your circuit is turned on?
« Reply #2 on: February 28, 2008, 09:35:24 PM »
I tried powering the OOPic with a fresh 9V battery, and no luck still. I just sent the OOPic in to get the board replaced instead.
