Author Topic: The Balancing Act  (Read 2433 times)
Offline CognautTopic starter
  • How do you know that I'm not a robot?
The Balancing Act
« on: December 08, 2006, 08:40:29 AM »
Does anyone know where I can get a perfect non-magnetic cube, about an inch on each side, with a fair amount of equally distributed mass?
I want to use it with 6 piezoelectric transducers in order to make a 3 axis accelerometer and orientation sensor.  It will be the "equalibrium" of my android.
Offline JesseWelling
  • Only You Can Build A Robot!
Re: The Balancing Act
« Reply #1 on: December 08, 2006, 09:33:41 AM »
How bout some plastic from here?
http://www.mcmaster.com/
« Reply #2 on: December 08, 2006, 10:13:38 AM »
I'm checking it out right now.  It does look like a promising vender.
I'm starting to think that maybe dense rubber would be a good option because I can squeeze it in for a tight fit.
I just measured my transducers.  They're actually a little under 9/8" in diameter.  So that's the size I'm looking for - 9/8"
« Last Edit: December 08, 2006, 10:38:11 AM by Cognaut »
« Reply #3 on: December 08, 2006, 10:46:15 AM »
I just found blank dice, sold in small quantities.
Last post April 25, 2010, 08:36:51 AM
by corrado33
Last post November 29, 2010, 05:59:30 PM
by ddemarco5
Last post January 09, 2012, 08:04:02 AM
by saiceg
Last post May 23, 2012, 12:59:31 PM
by Wesley888
