Author Topic: Servo output wheel spins out of center  (Read 2439 times)
Offline izuaTopic starter
« on: February 27, 2008, 04:47:08 PM »
I've taken out the electronics of two servos. I've put grease on the reduction mechanism. But even before beeing hacked, one of the servo output wheel was spinning out of center. It's not that noticeable, but it makes a weird sound when I connect the horn. There is still some skreeching without the horn.
I drilled holes through a wheel (although, they were drilled badly): 2, further away from the centerand at fixed locations, on the wheel's diameter (so holes + center are colinear) put resistors through the holes and into the servo horn. The wheel was spinning terribly out of center.
The same thing happens on the "good" servo. I've checked the unhacked servos, and those, too, seem to be spinning a bit off the center.
What should I do? No tutorial ever mentions something about this problems.
« Last Edit: February 27, 2008, 04:50:10 PM by izua »
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
Re: Servo output wheel spins out of center
« Reply #1 on: February 28, 2008, 11:48:02 AM »
Looks like the mold for the servo case is bad. Those servos are horrible. Get a brand name servo instead and you will not have this problem. This is the reason no one mentions anything about this in the modding tutorials. Try to find GWS servos, they are powerfull and verry good quality and cheaper than Hitech or Futaba.
« Reply #2 on: February 28, 2008, 07:25:15 PM »
so GWS are good servos and work like Hitec ones, rite?
I also heard that Hitec owns GWS or something
P.S.
Sorry for slightly hijacking this thread , even though its a bit on topic
Offline Ro-Bot-X
  • Helpful? 25
« Reply #3 on: February 29, 2008, 12:32:08 AM »
GWS standard servos are a little bigger than Hitech, but also almost double the torque. I am talking about S03T 2BB. I have seen bipeds with these servos and they work nice. In my arm they also hold their positions nice. I am very happy with them. I plan to buy more to make a byped someday.
« Reply #4 on: February 29, 2008, 12:35:00 PM »
Thanx for the input Ro-Bot -X
Next time i need servos, Ill check out the GWS ones
Offline Fredrik Andersson
« Reply #5 on: February 29, 2008, 12:43:18 PM »
You have my recommendations on GWS servos as well. The slightly larger size is the only problem I've encountered, but is not really a problem as i use custom brackets for my hexapod.
Current project: Pirrh - Portable Intelligent Round Rolling Hexapod
« Reply #6 on: March 03, 2008, 07:49:37 AM »
Thats because they operate at half the speed:
http://www.maximumrobotics.com/store/p/1029-S03T-2BB-Servo-w-JR-Connector.aspx
This is great for robot arms/legs, but bad for wheels.
Offline Mcrich113
« Reply #7 on: March 05, 2008, 12:03:32 AM »
Hey guys!
      You really need beter servos, all electronics correspond with age, so how old are your servos?Some good stores and companies are advertised here, look at them.
thanks!Mcrich113 ;D
Last post January 25, 2008, 08:57:18 AM
by javafiend
Last post November 09, 2008, 06:49:54 AM
by sdavis6736
Last post December 09, 2008, 08:11:21 AM
Last post July 27, 2011, 01:58:12 PM
by roboda
