Author Topic: Take a reading from a microphone  (Read 6473 times)
Offline airman00Topic starter
« on: February 27, 2008, 10:25:56 PM »
How can you take a reading of a microphone and interface it to a microcontroller? Would it be ADC or something else?
I found this schematic online
But are all those capacitors necessary , and also what would be the form of that signal( aka how do I interface it to a microcontroller)
Offline hazzer123
Re: Take a reading from a microphone
« Reply #1 on: February 28, 2008, 01:39:51 AM »
Im guessing the microphone's output is proportional to the pressure of the air at its sensor. So the output would be a sound wavel.
To record sound using a MCU, you would have a loop in which you sample the ADC and store it as an element of an array.
This would record 2 seconds of sound.
counter =0;
for(2 seconds) {
     soundRecordArray[counter] = Reading from ADC;
     counter++;
Say the human voice has a maximum of 4000 Hz when talking. You would have to sample at aout 4 x4000Hz to ensure each wave can be accurately recorded. If you sample at a lower frequency, you may find your recorder sampling only the peaks of a wave, which would then look like DC.
To play it back you would need a DAC.
www.icrobotics.co.uk
« Reply #2 on: February 28, 2008, 05:17:56 AM »
I see....
I want to compare the inputs of two microphones, to detect where the voice is coming from. So I would ADC on both and compare the readings, correct?
Offline paulstreats
« Reply #3 on: February 28, 2008, 06:22:50 AM »
Wouldnt you have to do something else such as convert it to a changeing voltage rather than a changeing amp for the adc to read it properly. Usually microphones emit an wave which is interpreted electronically as a change in the amps, the voltage level remains the same. When you amplify you usually increase the voltage level and the amps wave increases in proportion.
Offline benji
« Reply #4 on: February 28, 2008, 06:41:37 AM »
u gorra check mic output voltage levels and turn it to 0 >> 5 volts to get the best of you adc
mics give a very weak signal unless its attached to an amp
good ol' BeNNy
Offline Asellith
  • Helpful? 9
« Reply #5 on: February 28, 2008, 02:09:08 PM »
If you don't care about the sound only the sound level you might be able to feed it into a capacitor and read the overall voltage stored there. I'm doing this on the fly at work so it might sound crazy after I think about it some more  ;D  But the louder the sound into the mic the larger the RMS voltage will be if you filter that with a cap it might give you a rough estimate of the volume. If you sample from 2 different mics you might get a false positive because the second mic will read the voltage at a different time and might get the falling edge of the signal even though it had a larger peak. Ok now back to making wiring adapters for clocks. I can't wait till I grow up to be a real engineer. 5 more months!
Jonathan Bowen
CorSec Engineering
www.corseceng.com
« Reply #6 on: February 28, 2008, 02:53:38 PM »
The human voice contains formants important for distinguishing certain sounds of up to slightly above 6kHz.
To sample a frequency reliable, you need to sample at least twice that frequency (Nyquists theorem).
Offline hazzer123
« Reply #7 on: February 28, 2008, 03:57:36 PM »
Hmm thats what i got taught - (the Nyquist theorem) - but when i think about it, 2x doesn't seem enough. I might be wrong though ...
Heres why i think it's wrong
This is sampling at 2xf, yet the output is not what the input was.
« Reply #8 on: February 28, 2008, 09:52:17 PM »
Either you are. or the entire world of engineers working in some way with sampling digital signals (including me) are  ;D
That is what could happen at the Nyquist frequency (highly theoretical though, since no circuit has a frequency deviation of exactly zero.
If your sample speed is a bit too low, you would get false readings (the input would appear to be of a lower frequency), but as long as your sample speed is just a wee bit higher than twice your signal frequency, you're in the green.
CD audio sample speed is 44.1 kHz and the signal can go to 20kHz - does your CD's sound bad? (Not talking music taste here of course :))
« Reply #9 on: March 01, 2008, 10:40:48 PM »
http://www.societyofrobots.com/robotforum/index.php?topic=1125.0
« Reply #10 on: March 01, 2008, 10:42:42 PM »
I saw that,  :P
I just wanted to know how to take the actual reading
