Author Topic: $50 robot with differrent MCU, motors and sensors  (Read 2733 times)
Offline ajax spray n wipeTopic starter
« on: March 01, 2008, 08:59:40 PM »
I'm thinking of making the $50 robot, and I was wondering about making a few changes, such as:
  • Using a sonar rangefinder instead of the sharp IR rangefinder. The reason behind this is that the sonar rangefinder that I am looking at ,Maxbotix MaxSonar-EZ0 High Performance Sonar Module (http://www.robotshop.ca/home/products/robot-parts/sensors/ultrasonic-range-finders/maxbotix-ez0-ultrasonic-ranger.htm) has a 6.45 metre range , whereas the sharp rangefinders that I've seen only have 80 cm. I was wondering what kind of changes I would have to apply to the code so that it has the same function as the sharp, and whether I can mount this on a servo as well.
  • Using a Pololu Orangutan LV-168 Robot Controller With USB Programmer as the MCU. This MCU has 2 DC motor servos, which is useful for me, as I live outside the U.S., and it is about 10$ cheaper for a motor than for a servo. It includes the USB programmer, but I am hopeless at code  ??? so I'm wondering whether it will use the same .hex files etc. as the original $50 robot. Here's the site:http://www.robotshop.ca/home/suppliers/pololu-en/pololu-orangutan-lv168-controller-usb.html
Also, with the DC motors, they need 6-12V, and (with no load) a current of 0.3 A. Their speed is 18,400 RPM and they have 69.2g.-cm torque (at 12V). The MCU has an input voltage of 2-5V (step-up regulator makes it 5V) so will I need another power source for the motors?
If anybody can help, your advice is very much appreciated.
Re: $50 robot with differrent MCU, motors and sensors
« Reply #1 on: March 01, 2008, 09:01:45 PM »
those things will require A LOT of program changes
what is your experience with programming?
also, the orangutan is AVR based, rite?
« Reply #2 on: March 01, 2008, 09:17:37 PM »
The Orangutan LV-168 is based on Atmel's mega168 AVR microcontroller. I have no previous experience in anything short of html programming. Do you think I could build this from the beginning, or will I have to build the $50 robot with the normal components, and then buy the extras and add them later. I would prefer the first option, as otherwise my $50 robot, already around $200 will be about $300.
« Last Edit: March 01, 2008, 09:20:22 PM by ajax spray n wipe »
« Reply #3 on: March 02, 2008, 06:47:30 AM »
you'll need to change the code slightly if you use sonar  since sonar needs a trigger pulse for it to send out a sonar beam
please combine your related posts
i posted another answer for your questions over there
« Reply #4 on: March 02, 2008, 08:08:10 AM »
In the 50 dollar robot tutorial  you make the MCU board yourself
the Orangutan is also an MCU board , but what I would do is just add H bridges, etc. to the 50 dollar robot MCU board that you already made
« Reply #5 on: March 02, 2008, 08:21:19 AM »
You want to make so radical changes (Sort of like "I wanna build a Ford and I wanna use the motor from a Toyota and the chassis from a VW") that you should look at something else, like building from the ground up.
You will need substantial gear reduction to use these motors.
You'd need a power source supplying the 12V for the motors, but you can use a regulator (switch mode preferably) to get the lower voltage for the µcontroller and what else needs it.
If anyone could reccomend another similar MCU (based on ATmega168 chip, motor drivers/H-bridges, I/O ports for sonar.
You won't find a µcontroller with build in H-bridge (as you asked in another post).
As long as a µC has enough I/O's etc. you just add whatever is needed to control motors, read sensors etc., but judging from your questions, I'd guess, you aren't capable of making so radical changes as you seem to want.
Readjust your expectations and you'll have a lot of fun, but as it stands, I foresee a lot of disappointment coming to you.
« Reply #6 on: March 09, 2008, 10:52:26 AM »
The sonar will work without any code changes (if you use the sonar analog pin). Also, the accuracy will be much much lower.
http://www.societyofrobots.com/robot_faq.shtml#servo_motor
And it wouldn't really be the $50 Robot if you replace everything in the tutorial :P
Remember, keep your first robot simple, and worry about all those neat ideas you have for your 2nd robot. ;D
As for using the Orangutan, you'd have to change the pinouts that are in my code to match the schematic.
