Author Topic: $50 robot - atmega8 - int0 & int1  (Read 3008 times)
« on: March 03, 2008, 01:10:40 PM »
What are these ports for on the servo bus? I plugged a servo into them, and obviously nothing happend.
Also, Can the photosensors be plugged into any port on the sensor bus?
Offline ed1380
Re: $50 robot - atmega8 - int0 & int1
« Reply #1 on: March 03, 2008, 02:49:31 PM »
the servo ports in the code are portd 0 - portd4
the photosensors can be plugged into any one you'd just have to change the code a bit.
are you sure the atmega8 is programmed correctly? are the servo's plugged into the correct pins?
« Reply #2 on: March 04, 2008, 11:23:52 AM »
I learned from reading posts that the ports on the servo bus are controlled by the programming, not the actually way its soldered. I figured this out when I read ahead to the UART guide.
Right now I have only had the modify servo hex loaded. I should wait until my robot is fully programmed before asking such questions.
« Reply #3 on: March 15, 2008, 06:43:45 PM »
int 0 and int 1 are interrupts.
If you program them in, they can be useful for neat stuff. Just google them up to learn more.
Last post March 12, 2008, 11:25:57 AM
Last post September 14, 2010, 04:45:34 PM
by Webbot
Last post October 06, 2010, 01:47:50 AM
by cyberfish
Last post September 05, 2011, 09:06:45 AM
by billhowl
