Author Topic: RFID Transceiver, where is Rx and Tx?!  (Read 1896 times)
Offline AdminTopic starter
« on: March 03, 2008, 10:25:04 PM »
For a project I am working on, I am required to use this RFID device:
http://www.nordicsemi.com/index.cfm?obj=product&act=display&pro=64
nRF2401A Transceiver
Looking at the pinout, I can't figure out what is Tx and Rx.
I guess pin 3, Data Out 2, is Tx.
But where is Rx? And what does pin 7, Data Input Output, do?
I realize I haven't carefully read through the datasheet yet, but I have one week to build an entire custom robot arm (plus my normal 40 hour work week) and my brain is frying here . . .
Hope someone can help asap!
Offline frank26080115
Re: RFID Transceiver, where is Rx and Tx?!
« Reply #1 on: March 03, 2008, 10:58:15 PM »
That's not an RFID transceiver, I have two nRF24L01s from SparkFun, they are just really easy to use and reliable radios
Unless you want to use them as RFIDs...
Anyways, read page 16 and down for configuration info and timing diagrams, the most useful parts.
« Last Edit: March 03, 2008, 11:38:06 PM by frank26080115 »
Offline izua
« Reply #2 on: March 04, 2008, 06:08:01 AM »
you can try CC1000 or the rfxxxx chips from nordIC for a transceiver (both are smd)
« Reply #3 on: March 04, 2008, 09:36:52 AM »
Oops, I saw RFDi and somehow thought I saw RFID.
I am actually using the RFD21006, which supposedly has a nRF2401 Module in it. No idea what else it has, since I can't find a datasheet, just a pinout.
(I'd link you to it, but the www.rfdigital.com site won't allow a link to other than the main page . . .)
I'm still confused on where to connect Tx and Rx . . . I only see one DATA pin . . .
On page 9 on the datasheet I found this:
Mode               PWR_UP   CE   CS
Active (RX/TX)       1         1     0
My assumption is that I attach my mcu digital output lines to those three pins to control the transmission mode, plus ground and power. But . . . what about my Tx/Rx pins from my mcu, where do they go?
I'm also assuming I can ignore the CLK pins, right?
« Reply #4 on: March 04, 2008, 10:04:32 AM »
I really think it's synchronous, so you have to use SPI on your microcontroller and emulate another SPI interface with software, or use your USART in synchronous mode.
« Reply #5 on: March 04, 2008, 12:48:50 PM »
hmmmm complicated . . . by complicated I mean I'd have to figure out how to use SPI :P
Anyway, scratch this whole thread. My client recently decided this isn't the right technology for what he wants, so I'm not pursuing it any further.
Last post April 24, 2007, 06:16:14 PM
Last post June 30, 2009, 02:27:56 AM
by jamort
Last post May 16, 2012, 08:08:44 PM
by Hawaii00000
Last post January 22, 2013, 09:04:17 PM
by Webbot
