Author Topic: $50 robot not coming to life  (Read 3250 times)
« on: March 05, 2008, 11:59:16 AM »
OK so last night i finished my robot.
The voltages all look good.
I am using the 4.8v battery pack and the 9volt.
the sensor side is getting the 5 volts, and the servo bus is getting the 4.8volts.
still the wheels aren't turning?
any suggestions?
Offline Mcrich113
Re: $50 robot not coming to life
« Reply #1 on: March 05, 2008, 05:36:25 PM »
Double check everything, if u think about it, the servos are the only way to see if its working, some otherparts may still be working,take a pic of it and post it
Offline goatfish
« Reply #2 on: March 05, 2008, 09:13:33 PM »
have you downloaded that .hex file that  is mentioned in the modifying the servos tutorial?
« Reply #3 on: March 05, 2008, 09:30:40 PM »
Yeah I did all that.
I have the actually $50 robot hex uploaded right now.
Offline garriwilson
« Reply #4 on: March 05, 2008, 10:53:35 PM »
1. Did you plug the servos in correctly? The yellow wire goes next to the programmer. The middle is red. The outside is black. So yellow is closest to the atmega chip.
2. You didn't mention it, so did you program the robot successfully? Maybe there was an error in the programming?
Offline frank26080115
« Reply #5 on: March 05, 2008, 11:10:26 PM »
all grounds common? fuse bits in avr set correctly?
Offline Trumpkin
« Reply #6 on: March 06, 2008, 11:58:04 AM »
That doesn't matter, as long as he has modified the servos with the code he doesn't need to use that code for anything else.
Robots are awesome!
« Reply #7 on: March 15, 2008, 05:48:39 PM »
Dumb question but . . . did you plug the servos into the right spot?
Do the servos jitter when you plug them in?
Check the voltage on the servo wire itself (you will see some metal on the female header).
Last post August 31, 2007, 07:09:06 AM
Last post June 30, 2010, 11:02:27 PM
by voyager2
Last post January 29, 2011, 01:57:48 PM
by greywanderer012345
Last post August 28, 2012, 02:09:57 AM
by robotnao
