Author Topic: Motor Torque Sanity Check  (Read 1462 times)
Offline silo_xtremeTopic starter
  • I really love robots, they keep me awake at night.
« on: March 06, 2008, 08:52:50 AM »
Hi everyone,
I'm looking at a BLDC motor that has 4000 rpm, and provides 200W; which tells me that Torque is ~4.22 lb-in.
If i lower the rpm (via gears) to 100 rpm, I believe the theoretical Torque would be 4.22 lb-in * 40, resulting in a Torque of ~ 168.8 lb-in.
How would I know if the motor can actually support that amount of Torque?
Re: Motor Torque Sanity Check
« Reply #1 on: March 09, 2008, 11:45:52 AM »
Well, if you use gears, you will take an efficiency loss. Without knowing your system, I'd say ~80%.
experiment :P
If you use my RMF calculator, you can determine torque by knowing velocity from an experiment. Or you can find the stall torque by forcing your motor from rotating.
Last post January 19, 2008, 08:22:32 PM
by ed1380
Last post November 16, 2009, 03:43:13 PM
by baalexander
Last post February 14, 2010, 09:52:48 PM
Last post May 08, 2012, 07:50:08 PM
