Author Topic: where do i get photoresitors from.  (Read 2178 times)
Offline girishskTopic starter
« on: December 10, 2006, 12:37:37 PM »
I am newbie. I would like to know where can i get the photoresistors.
Does some one know the vendors who give out samples ?
As for my first project i require only 2.
Thanks in advance
Kathle
Offline sdk32285
Re: where do i get photoresitors from.
« Reply #1 on: December 10, 2006, 12:51:31 PM »
Heres a couple of sites.
www.newark.com
www.jameco.com
www.aliedelec.com
www.elexp.com
Photoresisters are failrly cheap. If you try calling the companies they might have some supplies that they can donate to your project/cause.
« Reply #2 on: December 10, 2006, 01:56:39 PM »
radioshack and digikey.com have them too
Offline Militoy
« Reply #3 on: December 11, 2006, 09:32:46 AM »
For only 2 pieces, I recommend Radio Shack (if they have what you need). Almost any part is available directly from the manufacturer as samples – but typically only to design functions of OEM manufacturers, who are buying components in quantity. Still – it doesn’t hurt to ask! Digi-Key is a good source of a wide variety of parts – as well as a guide to which parts may be readily available, and which may be hard to find. The only hassle with them for smaller purchases is that they have a minimum order amount – I think $25 now. When I select a part from a manufacturer’s website or catalog, I’ll often look up the part on Digi-Key’s site, to make sure I’m not picking a part that will be hard to source. If their stock status is “0” quantity, that’s a red flag. As a side note to those using Digi-Key or Newark, etc. exclusively, there is a good site that will check both price and stock status of multiple sources – FindChips.com. You just enter in your part number there, and you’ll find out which distributor has stock at the best price.
