Author Topic: hookup wire  (Read 2856 times)
hookup wire
« on: March 06, 2008, 07:12:55 PM »
What hookup wire is used in the $50 robot tutorial?
I found some left over hookup wire that I used..lesson learned it was really too thick and clumsy.
Where is a good place to get hookup wire? what gauge is best for robots? 22? 24?
-Brandt
Offline HDL_CinC_Dragon
Re: hookup wire
« Reply #1 on: March 06, 2008, 07:34:21 PM »
Either or, depends on the application. You can go as low as 26 if you wanted to. I usually use between 22 - 26. whatever is most conveniently at hand. But when im soldering into a perf board, i might use 20
Hope this helps
United States Marine Corps
Infantry
Returns to society: 2014JAN11
Re: hookup wire
« Reply #2 on: March 07, 2008, 11:25:26 AM »
Where is a good place to buy it?
Radio shack doesnt go any lower than 22 guage and doesnt have a very good selection of colors.
it seems like digikey only sells in bulk.
Re: hookup wire
« Reply #3 on: March 07, 2008, 04:19:54 PM »
22 gauge is fine. Perfect even.
Infantry
Offline Trumpkin
Re: hookup wire
« Reply #4 on: March 07, 2008, 04:37:59 PM »
go to radio shack to buy it. the gauge they sell is fine, it worked for me.
Robots are awesome!
Re: hookup wire
« Reply #5 on: March 13, 2008, 12:12:35 PM »
I used stranded core (16 gauge maybe?)  on my $50 robot board. Horrible.
Radio Shack sells 22 gauge solid core.
Solid core or stranded core for boards and sensors?
Offline Trumpkin
Re: hookup wire
« Reply #6 on: March 13, 2008, 01:54:06 PM »
Oooh always use solid wire ;). Stranded stinks.
Robots are awesome!
Re: hookup wire
« Reply #7 on: March 13, 2008, 05:17:38 PM »
Infantry
Offline Trumpkin
Re: hookup wire
« Reply #8 on: March 14, 2008, 08:36:45 AM »
I'm sure there is some use for stranded wire, just can't think of any right now.
Robots are awesome!
Offline bukowski
Re: hookup wire
« Reply #9 on: March 14, 2008, 10:01:48 AM »
Trumpkin, use stranded wire for higher current applications, or with high frequency AC (because of skin and proximity effect), or when you need more flexibility.
Offline Trumpkin
Re: hookup wire
« Reply #10 on: March 14, 2008, 10:32:59 AM »
Aah, I knew about the flexibility part but i didn't know that your supposed to use it for high currents.
Robots are awesome!
Re: hookup wire
« Reply #11 on: March 14, 2008, 09:11:14 PM »
I use it for soldering main lines on my boards
Infantry
  • Helpful? 172
Re: hookup wire
« Reply #12 on: March 16, 2008, 07:35:49 PM »
22, 24, and 26 gauge will all work fine
