Author Topic: omni drives  (Read 3163 times)
Offline AdminTopic starter
omni drives
« on: December 10, 2006, 01:55:38 PM »
looks like an impressive chassis . . . definitely a complex design . . . inspiring too . . . although the video makes it look less than impressive i think . . .
pics
http://azimut.gel.usherbrooke.ca/pagephotos.html
video
http://azimut.gel.usherbrooke.ca/video/AZIMUT_TEASER.mpg (70mb)
they have a similar robot here made by the same people:
http://www.robomotio.com/azimut2.php
doesnt seem to work that much different than my old bot i made
http://www.societyofrobots.com/robot_taurus2.shtml
Offline Militoy
Re: omni drives
« Reply #1 on: December 10, 2006, 06:34:11 PM »
The video took too long to load on my laptop, so I moved down to watch your video of Taurus 2 instead. Nice, smooth motion control! It does kind of bring to mind the design of the Mars Rover. I enjoyed seeing the Roomba at work at the same time Taurus was following the line.
Offline Dosbomber
Re: omni drives
« Reply #2 on: December 12, 2006, 02:46:15 AM »
Apparently Azimut doesn't do stairs, but it's quite adept at dragging lazy frenchmen around in their office chairs.
What scared me is that it took 2 guys to lift it off the pedestal... ooof!
It's basically a hybrid of the 4-point omni-directional movement approach (ala Taurus2, etc.), coupled with the split-track traction you see in a lot of today's robots (usually a triangular front section that can move up/down to climb obstacles).
Dosbomber
Offline JesseWelling
  • Only You Can Build A Robot!
Re: omni drives
« Reply #3 on: December 12, 2006, 10:52:59 AM »
I think if they added another joint to make the leg more insect like it would be great.
What I mean is a leg joint between it's boddy and tank tread....then it would for sure be able to walk any where
it couldn't travel by tank action.
Last post November 03, 2007, 10:24:02 AM
by HDL_CinC_Dragon
Last post June 16, 2008, 05:59:41 AM
by paulstreats
Last post November 30, 2012, 03:45:00 AM
by newInRobotics
Last post May 09, 2013, 10:16:35 AM
by GotServo
