Author Topic: double assigned to double gives error  (Read 2626 times)
Offline frank26080115Topic starter
« on: March 10, 2008, 08:09:36 PM »
int accelToAngle(int accel_)
double accel = accel_;
double accelZ_ = accelZ;
double angleRad = atan2(accel, accelZ_);
double angleDeg = (angleRad * 180) / 3.14159;
int angleDeg_ = angleDeg;
return angleDeg_;
won't compile, error not shown, only .elf file was never generated
double angleDeg = 0;
return angleDeg_;
this will compile with no errors.
how do I do double calculations?
I'm using avr studio.
Offline Tsukubadaisei
Re: double assigned to double gives error
« Reply #1 on: March 10, 2008, 08:27:17 PM »
Where is the accelZ variable comming from? is it a global variable?
And what is atan2()? If you are using math.h then I think it is atan().  If it is a custom function show us the code or try using atan().
What is the difference between accel and accel_, accelZ and accelZ_, angleDeg and angleDeg_?
Finally, in the 7th line, it is written:
int angleDeg_ = angleDeg;instead try this
int angleDeg_ = (int)angleDeg;
« Reply #2 on: March 10, 2008, 10:11:56 PM »
the differences between the names are their type
atan2:
The atan2() function computes the principal value of the arc tangent of __y / __x, using the signs of both arguments to determine the quadrant of the return value. The returned value is in the range [-pi, +pi] radians.
that doesn't cause the compile error
accelZ is global, it's an int
basically, I can't assign angleDeg to anything else but a constant
my chip is a atmega644 with PLENTY of room left.
« Reply #3 on: March 11, 2008, 03:05:10 AM »
From your code I could see you do some redundant things. And one of them is creating and assigning this angleDeg constant. Since it is just a instance for this function you wont be able to use it elsewhere. So try this code:
float accel = accel_;
float accelZ_ = accelZ;
float angleRad = atan2(accel, accelZ_);
return (int)((angleRad * 180) / 3.14159);
That is assuming that you have no trouble with angleRad.
If you have trouble with angleRad try this:
float accelZ_ = (float)accelZ;
return (int)((atan2(accel, accelZ_) * 180) / 3.14159);
I am not an Atmega expert(I have just used the Atmega32 and 128) so there might be a remote possibility that "casting" is not implemented in your compiler. So should be a good idea try another compliler if everything else fails.
But since both Atmega32 and 128 have "casting" implemented  I doubt that.
If you still have trouble please post the source of atan2() and the type of accel_ (int or double or float).
By the way I used float instead of double, just in case. Try with that and see what happens. If you want try with double (but I hardly believe you need that pecision).
« Reply #4 on: March 11, 2008, 05:40:29 PM »
I've been trying out different ways all day, but i've resorted to generating lookup tables
I think the problem is that math.h doesn't work at all, it's supposed to compute constants on the computer because of the optimization my compiler does. If I actually try to use them for variables, no dice
« Reply #5 on: March 11, 2008, 10:28:49 PM »
that is strange because I use math.h with atmega32 and atmega128 and it works(though I dont remember using atan()). My compiler is the gcc. Maybe you should try using gcc if you are not using it already.
Anyway, If you still want to try using a function there is one last resource I could recomend: Taylor expansion.
http://en.wikipedia.org/wiki/Taylor_series#List_of_Taylor_series_of_some_common_functions <- search here for arctan.
Just implement the function until the fourth term and you will have enough precision.
That is everything I have to say. That is what I whould have done as my last resource. Good luck!
Offline JesseWelling
  • Only You Can Build A Robot!
« Reply #6 on: March 11, 2008, 10:51:08 PM »
I'm guessing the constant needs a qualifier.
double angleDeg = (angleRad * 180) / 3.14159f;The f would qualify it as a float, but I can't seem to remember what the double qualifier is at the moment. But any ways, you get the idea  ;)
By the way this is also a good place to start with weird AVR specific problems: http://www.nongnu.org/avr-libc/
« Last Edit: March 11, 2008, 10:55:09 PM by JesseWelling »
Offline JonHylands
« Reply #7 on: March 12, 2008, 06:44:27 AM »
Try this:
double angleDeg = (angleRad * 180.0) / 3.14159;
- Jon
