Author Topic: $50 wall avoidance?  (Read 2845 times)
$50 wall avoidance?
« on: March 11, 2008, 03:50:16 PM »
When I do the IR upgrade to my $50 robot, I understand that it will then chase a target, but does that work in conjunction with the photoresistors to go after light and chase objects? Also is there a way to add wall avoidance?
So far my robot is pretty lame  :-\  It just goes straight in the dark until it runs into a wall and then keeps going  ;D and then when its in full light (like the kitchen) it just goes in circles!!!  ???
Offline HDL_CinC_Dragon
Re: $50 wall avoidance?
« Reply #1 on: March 11, 2008, 08:56:29 PM »
no no, the IR upgrade doesnt make it chase targets. It gives it a more reliable chance of seeing the things in front of it and avoiding them(unless you program it to attack whatever it sees).
United States Marine Corps
Infantry
Returns to society: 2014JAN11
Offline paulstreats
« Reply #2 on: March 12, 2008, 04:10:00 AM »
The sharp ir upgrade does make it chase targets but it doesnt work in conjunction with the photoresistors (which is lucky since yours isnt working properly)
Offline cooldog
« Reply #3 on: March 12, 2008, 07:34:51 AM »
search the forum :P
http://s236.photobucket.com/albums/ff16/robvandiver/?action=view&current=121107_1201.flv
http://s236.photobucket.com/albums/ff16/robvandiver/?action=view&current=121107_1157.flv
Hope those links work.
Ok, so this is $50 robot with the sharp IR rangefinder upgrade version 2: the object avoider.
Still working out some kinks, like I have to get the rangefinder with the longer range, and finding "the perfect range" to work with. Right now Im still autocalibrating it every time I turn it on. Im sure the code could be better, I just changed a couple of lines, but not too bad for someone that knows nothing about anything!
*   Copyright (c) 2007 www.societyofrobots.com
*   (please link back if you use this code!)
*   This program is free software; you can redistribute it and/or modify
*   it under the terms of the GNU General Public License version 2 as
*   published by the Free Software Foundation.
*   Alternatively, this software may be distributed under the terms of BSD
*   license.
* $50 Robot with Sharp IR using Stampy Technology v1, May 19th, 2007
* Simple case-based method for a robot to do edge detection.
//SoR Include
#include "SoR_Utils.h" //includes all the technical stuff
//global variables
int sharp_IR_reading=0;
int scan_thresh=0;//threshold value of scanning sensor
int scan_angle=30;//position of scanner, in units of servo command
int max_scan_angle=56;//maximum position scanner can rotate to (57)
//this function causes scanning servo to center on edge of object
void scan(void)
//lower (-) goes right
//higher (+) goes left
//30 far right, 50 straight, 56 far left (until it jams)
sharp_IR_reading=a2dConvert8bit(3);
if (sharp_IR_reading > scan_thresh)//object detected
if (scan_angle>41) //overflow protection
scan_angle-=2;//scan right
else //object not detected
if (scan_angle<=max_scan_angle) //maximum servo angle
scan_angle+=2; //scan left
else //if scanned all the way, this forces it to start over
scan_angle=30;
//servo scan code
servo_scan(scan_angle);
//automatically calculates threshold value before run
void autocalibrate(void)
scan_thresh=a2dConvert8bit(3);//sensor reading
int main(void)
//LED_on();
initialize();
delay_cycles(42000);//two second wait delay
/*********ADD YOUR CODE BELOW THIS LINE **********/
//find thresholds
autocalibrate();
//LED_off();
while(1)
scan();
robot_turn_right();
//object is centered
else
robot_go_straight();
delay_cycles(400);//a small delay to prevent crazy oscillations
/*********ADD YOUR CODE ABOVE THIS LINE **********/
return 0;
/*********************COMMAND LIST*************************
delay_cycles(cycles);
Delays - you can make your robot wait for a certain amount of time with this function.
Put the number of computational cycles to delay in the ().
23 cycles is about .992 milliseconds
to calculate: 23/.992*(time in milliseconds to delay) = cycles
Check servo datasheet where it says: 'Direction: Clockwise/Pulse Traveling 1500 to 1900usec'
servo_left(speed); and servo_right(speed);
Commands your servos to rotate at a certain speed.
Vary speed (which represents a delay in cycles) from 20 to 50.
Left is for port D0 and right is for port D1.
robot_turn_left(); and robot_turn_right(); and robot_go_straight();
Dont want to deal with speed?
Just call this function and it will 'just work.'
LED_on(); and LED_off();
Turns on and off your LED. The LED is on port D4.
By bringing port D4 low, you are turning on the LED.
variable=a2dConvert8bit(pin);
Reads analog pin. For example, set 'pin' to 5 to read PC5.
'variable' will store the value.
anyways, any suggestions for how I could make it work better or anything I did wrong are welcome!
-admin
favorite web sites
http://www.instructables.com/
