Author Topic: strange pwm problem  (Read 2132 times)
Offline superchikuTopic starter
  • cooll
strange pwm problem
« on: March 12, 2008, 07:03:35 AM »
i hope my bot would start working it has got a strange probelm in pwm ,
when it is tested with only the mcu in the breadboard , i get exactly same values of pwm but when used in the bot one is lower than the other i dont know why this is happening can u help
and yes  both of my adc configurations are same so their corresponding pwm must be same so wat is the problem
mcu:atmega16
pwm channel used:oc0 and oc2
same prescaler and values
ADC:reference is AVCC and i have connected capacitor between aref and GND???
JAYDEEP ...
IT AND ROBOTICS ENGINEER
Offline HDL_CinC_Dragon
Re: strange pwm problem
« Reply #1 on: March 12, 2008, 02:25:17 PM »
electrolytic or mylar capacitor?
United States Marine Corps
Infantry
Returns to society: 2014JAN11
  • cooll
« Reply #2 on: March 12, 2008, 02:36:32 PM »
mica capacitor electrolytic would just blow up
JAYDEEP ...
  • cooll
« Reply #3 on: March 12, 2008, 02:38:35 PM »
it works on the breadboard but on the main crcuit board it just gets mad doing strange things with pwm
and yes i have triple checked the connections
JAYDEEP ...
Offline ed1380
« Reply #4 on: March 12, 2008, 02:53:31 PM »
what is this main circuit board you're talking about? is it through hole, custom made pcb? etc.
  • cooll
« Reply #5 on: March 14, 2008, 06:49:17 AM »
main circuit board means the veroboard which is going to be attached to the bots
JAYDEEP ...
« Reply #6 on: March 15, 2008, 07:00:59 PM »
Is your ADC somehow controlling the PWM?
your cap isn't rated at the right voltage
yeap, you need a cap there too
  • cooll
« Reply #7 on: March 16, 2008, 01:06:15 AM »
thanks for the reply i found out the problem since iam using 2 different timers ,they are acting differently when connected to the veroboard i have adjusted the code accordingly and soon will be posting my bot's video
JAYDEEP ...
