Author Topic: DC motor controller  (Read 2905 times)
Offline DanCFTopic starter
DC motor controller
« on: December 11, 2006, 11:32:57 AM »
I just bought an MCU to control all my servos, however I also have an 18 amp motor (12V) which I would also like to control. I understand that there are cards out there which are made specifically to control DC motors. The problem that I am having is that most only support 4 amps or so. Does anyone know where I can find a controller that will support atleast 22 amps (ideally higher because I may need to upgrade)?
Re: DC motor controller
« Reply #1 on: December 11, 2006, 11:40:17 AM »
Ok, what you want is a motor driver (search the forum for more info).
22amps is really high . . .
this can do 20A continious (30A peak)
http://www.dimensionengineering.com/SyRen20.htm
check this parts list for motor controllers and drivers
http://www.societyofrobots.com/robot_parts_list_electronics.shtml
« Reply #2 on: December 11, 2006, 11:49:56 AM »
Alright well the motor is only 18 amps, but I dont know what the rule of thumb is with amp padding. The one you listed would probably work. I don't see a serial port on that driver, does that connect to my MCU?
« Reply #3 on: December 11, 2006, 11:57:01 AM »
I found this controller which provides more amps, and is a little cheaper, it just doesnt have all the bells and whistles of the other one: http://www.lynxmotion.com/Product.aspx?productID=493&CategoryID=10.
It mentions that a .05HP motor is the maximum it can handle. Why would the HP matter as long as you are within the necessary amp and volt range?
« Reply #4 on: December 11, 2006, 12:00:45 PM »
my rule for current is:
the allowable continuous current of the driver should be higher than motor stall current.
the 4th paragraph:  :P
"you can control a motor with: analog voltage, radio control, serial and packetized serial"
I recommend using a digital output pin of the microcontroller to do the radio control method.
« Reply #5 on: December 11, 2006, 12:06:41 PM »
HP doesnt really matter . . . torque relates to current and voltage, but means nothing to circuit design. I think they wrote that just in case you dont know how to spec for current and voltage of a motor. Just use the specs at the bottom . . .
Last post October 19, 2007, 08:17:21 PM
Last post June 14, 2009, 11:50:15 AM
by RoboChan
Last post December 10, 2009, 03:38:03 PM
by definitionofis
Last post April 16, 2011, 10:17:31 AM
by BANE
