Author Topic: Difficulty of building small AGV?  (Read 2670 times)
Offline maverick monkTopic starter
« on: March 13, 2008, 03:08:25 PM »
Im looking at possibly building a agv (autonomous ground vehical) for testing settups involving telepresence and payload carrying, as well as... airsoft  8)
the plan is for a 1.2ghz or 2.4ghz video camera reporting to a 2.5inch lcd screen on my person. what is the best drivetrain option? Is this too big a project to do with servos for continuous rotation? what servos should I use? what wheels? or is there a cheap, mid-scale track solution that can scale outdoor terrain (picture paths in the woods, ocasional branches, rocks, leaves, hills, groundhog holes, ect.) advice for building material? I was thinking expanded pvc or HDPE, maby delrin. also, will a IR lamp provide illumination for a 2.4ghz camera at night?
Offline cooldog
Re: Difficulty of building small AGV?
« Reply #1 on: March 13, 2008, 06:16:46 PM »
it shouldn't be
HS-311 should be good but you may need stronger
what wheels?
how many wheels
plexy glass or aluminum
i would think so
keep us posted ;D ;D
-admin
favorite web sites
http://www.instructables.com/
« Reply #2 on: March 13, 2008, 07:47:24 PM »
I would say four wheels, anything more then that and without independent suspension it becomes LESS menuverable. What kind of range should I expect from a 2.4ghz camera?
« Reply #3 on: March 13, 2008, 08:42:57 PM »
depends how much you want to spend on the camera ,  ;)
Tell us what range you WANT and then wie'll advise a good cam
Be sure to post pics of it when you are done with it!  ;D
« Reply #4 on: March 14, 2008, 07:59:37 AM »
no more then 70 for a camera and receiver, 100 for 2 cameras and 1 receiver, i just figured how to do a normal cam and a 3x magnification cam...more later
« Reply #5 on: March 15, 2008, 02:40:30 PM »
The choice of drivetrain depends significantly on your terrain, and the required speed, range, torque, and robot weight.
Hobby servos should only be used on small robots . . .
« Reply #6 on: March 15, 2008, 03:43:50 PM »
Size is looking to be no more then 18inches long, and shouldent weigh more then 1kg. My terrain as stated will be light offroad, with small obsticals like branches, stones, ect.
