Author Topic: GPS robot help  (Read 2406 times)
Offline 555 timer chip guyTopic starter
GPS robot help
« on: March 15, 2008, 04:11:54 PM »
I am building a robot that uses GPS to navigate beatwen two points. I need a way for the robot to calculate the heading to take from point 1 to point 2 using latitude, longitude, and a compass heading. I have one formula that I have created that works grate, but it is to complicated for the MCU on the robot to use.
Please help.
Re: GPS robot help
« Reply #1 on: March 16, 2008, 07:52:41 PM »
Why is it too complicated?
Can you post what you have?
Use a compass heading to point the bot in the desired heading.
Then use highschool trig to determine the required driving distance between both current and desired locations.
Offline frank26080115
Re: GPS robot help
« Reply #2 on: March 16, 2008, 10:06:40 PM »
GPS is not that accurate on a small scale to get the heading of a small robot, a car is a different story since it's fast.
I'm trying to use
http://www.sparkfun.com/commerce/product_info.php?products_id=761
but it's more trouble than it's worth
Try this
http://www.sparkfun.com/commerce/product_info.php?products_id=7915
Other than that, have a function that mixes motor speed, and store headings in a signed integer, calculate the difference between current heading and desired heading and plug into the mixing function.
If trig is a problem, generate a lookup table
« Last Edit: March 16, 2008, 10:08:49 PM by frank26080115 »
Re: GPS robot help
« Reply #3 on: March 18, 2008, 05:37:08 PM »
Thats just it I am using a compass for heading But my MCU is not smart enough to do trig.
Re: GPS robot help
« Reply #4 on: March 23, 2008, 08:28:36 AM »
Ohhhh you mean you know how to do it, but your MCU can't handle it . . .
Get a better MCU :P
AVR, PIC, and ARM can handle it. My Axon can easily handle that, too.
edit:
considered using a lookup table?
« Last Edit: March 23, 2008, 08:29:31 AM by Admin »
Re: GPS robot help
« Reply #5 on: March 25, 2008, 11:55:37 AM »
?????????????????  what is a lookup table? ???
Offline AndrewM
Re: GPS robot help
« Reply #6 on: March 25, 2008, 02:45:36 PM »
Each trig function has a base range, or domain.   Everything beyond that range is just multiples of pi or repeats of previous values, depending on the function.  A lookup table is an array of values that you can use to store this base range.  For instance, lets say you were using the "Sine" function to compute your locations.  You could create an array variable(lets call it SINLOOKUP) in memory containing the values of the sine function, such that where X is equal to the numerical count of the array (SINLOOKUP[X]), the value of SIN(X) is stored in that spot.  Now when you need to know what the sine value is of 47, you just "look up" item number 47 in your array.  Basically:  SINLOOKUP[X] = sin(X).  You can also do the same thing a variety of other ways depending on your processors capabilities.
blog: www.iamwhen.com
Re: GPS robot help
« Reply #8 on: April 16, 2008, 12:01:58 PM »
Never mind I got a new MCU that has trig functions built in.
Thanks for all the help.
Last post February 08, 2007, 01:23:07 PM
by hgordon
Last post February 14, 2007, 11:09:24 AM
by annoyin_kid
Last post February 19, 2007, 08:04:33 PM
by ComputerGeek
Last post February 06, 2009, 03:19:09 AM
by ang5t
