Author Topic: wire controlled robots???  (Read 2289 times)
Offline harisankarsaTopic starter
« on: March 20, 2008, 11:09:35 AM »
how can you make wire controlled robots for just moving around as you tell them to...ie to make it go forward,back,left and right...pls give me a simple logic...i am a beginner....
Offline cooldog
Re: wire controlled robots???
« Reply #1 on: March 20, 2008, 05:06:31 PM »
just get a couple of motors an ook them to switches
-admin
favorite web sites
http://www.instructables.com/
Offline superchiku
  • cooll
« Reply #2 on: March 20, 2008, 10:25:05 PM »
hey thats easy just attach the wires to the switches and then to the motors give power to the motors and move them around using switches
JAYDEEP ...
IT AND ROBOTICS ENGINEER
« Reply #3 on: March 20, 2008, 10:33:27 PM »
double poled switches are necessary
Offline benji
« Reply #4 on: March 21, 2008, 03:48:40 PM »
this is pretty much depends on what motors u are using
using servos are the easiest but you have to modify it to make full turns so you bot can go forward
using dc motors is not a bad idea but you have to attach a break circuit for the motor to stop
usually they give it a fast reverse high voltage but its not always a good idea cuz it doesnt provide ya precise motion.
you can also use steppers but that would be a little more complicated for a beginner to program it ,but it still pretty precise
another dis of it is that it could be a little more expensive that the other two
good ol' BeNNy
Offline ed1380
« Reply #5 on: March 21, 2008, 04:49:34 PM »
servos !=easiest.
2 gearmotors + 2 DPDT switches + some bateries and wire =easiest
Offline benji
« Reply #6 on: March 21, 2008, 05:43:43 PM »
what do you mean by gearmotors? arent they dc motors?
good ol' BeNNy
Offline ed1380
« Reply #7 on: March 21, 2008, 06:18:52 PM »
yeah. gearmotors are DC motors with integrated gearboxes
Offline superchiku
  • cooll
« Reply #8 on: March 21, 2008, 11:07:00 PM »
dc motors with high torque are geared like in servos
JAYDEEP ...
Offline benji
« Reply #9 on: March 22, 2008, 05:22:43 AM »
so its a compremize between speed and torque ???
good ol' BeNNy
Offline paulstreats
  • Helpful? 20
« Reply #10 on: March 22, 2008, 08:46:16 AM »
there is alsways a compromise between speed and torque.
The motors are easiest because you can just have them, a battery and a couple of switches to make it go. If you use a servo, then you need a microcontroller and programming and everything else that goes with it.
Offline benji
« Reply #11 on: March 22, 2008, 10:52:15 AM »
does it break perfectly?
good ol' BeNNy
Offline superchiku
  • cooll
« Reply #12 on: March 23, 2008, 12:20:12 AM »
hey more speed and high torque are very difficult to get so u have to be satidfies with what u have
JAYDEEP ...
Last post August 15, 2007, 09:43:34 PM
by dinzzud
Last post August 12, 2007, 04:13:27 PM
by maverick monk
Last post April 20, 2008, 06:34:41 PM
Last post October 03, 2011, 06:33:01 PM
by algar32
