Author Topic: $50 robot design  (Read 2284 times)
Offline SpiffyguyTopic starter
$50 robot design
« on: March 20, 2008, 05:35:28 PM »
I wanted to get some opinions on my design before I start putting it together.  Experience is always the best voice.  Basiclly I am doing a revered trike.  Battery is underslung green board on top will be my electronics.  I a have not started that part yet.  The rear caster has me a bit worried, mainly because it is cheap and may lock up.  Will not really know until I try it though.  And I had them so no cost there.  I plan on putting the photoresitors in some sort of case and then mount them.  Maybe a ball point pen case?  Something along those lines.  What sort of angle do they need to be at?  I figure it is trial and error but a place to start would help.  Anyway if you see anything blatantly wrong please let me know.  I plan on starting construction next week.  Oh do I need to use a breadboard to zero out the servos or can that be done once all the electronics are completed?
Front
Side.  the caster does rotate.  I am just not that good at sketchup yet
bottom
Re: $50 robot design
« Reply #1 on: March 20, 2008, 09:36:28 PM »
angle of the photoresistors doesn't really matter , just make sure they are pointing slightly upwards to see light from above
to modify the servos you need to give them a pulse to "zero" or center them
You could center the servos after the circuit board is made ,you just need to change the code on the microcontroller
« Reply #2 on: March 20, 2008, 09:53:24 PM »
ok cool.  I figure eventually I will a sharp IR or something else on the front end.  I will work on the circuit and get that done first.  Then center up the servos.  So the chassis looks ok though?
« Reply #3 on: March 20, 2008, 09:55:45 PM »
chassis looks good
is everything done to scale?
http://www.societyofrobots.com/member_tutorials/node/70
« Reply #4 on: March 20, 2008, 10:03:13 PM »
yeah everything is pretty close.  I think the back wheel will need a spacer or two to keep the deck level with the front tires.  Kinda hard to tell with sketch up.  I wish it had a 3 pane view like some other modeling programs I have used.  But I got out my ruler and measured everything.  Deck is 4" wide and 8" long.
« Reply #5 on: March 20, 2008, 10:05:37 PM »
if you really want a 3 pane view then save it as a .dwg file from sketchup
and use a free DWG viewer to open it up. Vola , 3 views
« Reply #6 on: March 21, 2008, 08:38:03 AM »
I may just have to do that.  just to get a figure on how far the back wheel is off the ground.  Sketch is not that bad to use.  I still have trouble with the move tool, getting it to go the right way.  which is why a 3 panel view would be cool.  Maybe they will add it one day.
Last post January 24, 2008, 10:52:03 AM
Last post March 04, 2008, 07:32:40 PM
by Mcrich113
robot design
Started by affy Misc
Last post July 05, 2008, 11:41:00 AM
Last post September 06, 2008, 01:01:14 AM
by ang5t
