Author Topic: Sharp IR Ranger Finder Quick Question  (Read 2970 times)
Offline sky099Topic starter
« on: March 21, 2008, 08:54:16 PM »
Hi, just wanted to ask a quick question about a Sharp IR Range Finder, we wanted to know if one of these would be able to read or bounce off IR light from a transparent acrylic surface, as in transparent walls. We're kinda stuck on that info, thanks in advance
Offline superchiku
  • cooll
Re: Sharp IR Ranger Finder Quick Question
« Reply #1 on: March 21, 2008, 11:06:03 PM »
never tested on a transparent surface why dont u test it and find it out
JAYDEEP ...
IT AND ROBOTICS ENGINEER
Offline Darkbluestar
« Reply #2 on: March 21, 2008, 11:59:06 PM »
I have tested it on Lexan which is a clear plastic(like plexiglass only stronger) and the IR did not detect it. So it goes right through lexan. Hope that helps
Offline airman00
« Reply #3 on: March 22, 2008, 06:44:41 PM »
yep thats true
for my robocup junior competition I found out the walls were plexiglass and switched out my IR for sonar
Offline superchiku
  • cooll
« Reply #4 on: March 23, 2008, 12:15:50 AM »
its obvious ir still is just light so it will pass through transparent sufaces
JAYDEEP ...
Offline airman00
« Reply #5 on: March 23, 2008, 06:28:51 AM »
not necessarily
some materials that appear translucent to us in the normal light spectrum,  are solid to IR light. Like you ever notice on a remote control box you have like semitransparent dark plastic. Well you can't really see through it but IR goes straight through.
Offline superchiku
  • cooll
« Reply #6 on: March 23, 2008, 08:17:24 AM »
well there are exceptions
JAYDEEP ...
« Reply #7 on: March 23, 2008, 08:22:24 AM »
(opaque, not solid) . . . but yes, exactly. There are transparency charts for materials vs. spectrum around if you just google around for it.
I can tell you for certain that glass is transparent, water is translucent, and snow is opaque in the IR spectrum.
The general rule of thumb is: anything that absorbs heat easily/quickly is opaque in IR.
Offline superchiku
  • cooll
« Reply #8 on: March 23, 2008, 08:23:50 AM »
wont glass absorb heat if it is heated??
JAYDEEP ...
Offline airman00
« Reply #9 on: March 23, 2008, 08:39:23 AM »
it wont heat up quickly like metal
Offline superchiku
  • cooll
« Reply #10 on: March 23, 2008, 08:44:25 AM »
still i dont think admin's explanation is complete
JAYDEEP ...
