Author Topic: $50 robot schematic  (Read 2773 times)
Offline lkikTopic starter
$50 robot schematic
« on: March 21, 2008, 11:34:01 PM »
dose any one have a better schematic for the $50 robot because that color coded one is bad well mainly because it does not tell you where to put the male breakaway header and what to connect to it i want to no so i can make it neat looking and so i can change stuff out so i can just keep on using it for other projects
Offline superchiku
  • cooll
Re: $50 robot schematic
« Reply #1 on: March 21, 2008, 11:48:28 PM »
well have u gone throught the whole tutorial its very well written and clear
it is very clearly mentioned where to put the male header pins just read it carefully and ull understand everything well
JAYDEEP ...
IT AND ROBOTICS ENGINEER
« Reply #2 on: March 22, 2008, 02:16:18 AM »
but i like normal schematic
  • Helpful? 111
« Reply #3 on: March 22, 2008, 01:02:15 PM »
You may like to see my PDF attached to the following post
http://www.societyofrobots.com/robotforum/index.php?topic=3292.msg25198#msg25198
« Reply #4 on: March 22, 2008, 04:54:18 PM »
yea that is good enouth 4 me
Offline superchiku
  • cooll
« Reply #5 on: March 23, 2008, 12:18:02 AM »
gud luck with ur bot then
JAYDEEP ...
