Author Topic: Cutting hole in thick metal in PGH/CMU area  (Read 1779 times)
Offline boulderjoeTopic starter
« on: March 25, 2008, 08:44:50 AM »
Does anyone have know where I could use the tools to cut a 2.5" hole in a metal box in the PGH/CMU area? Or know of a place that I can get this done?
I have been using a nibber and a dremel but the hole is not... pretty or round at that point ;)
Thanks,
-Joe
Re: Cutting hole in thick metal in PGH/CMU area
« Reply #1 on: March 25, 2008, 08:57:25 AM »
I should add its only 1/8" thick metal, from an army surplus box.
Thanks,
-Joe
Offline bukowski
« Reply #2 on: March 25, 2008, 10:34:59 AM »
Since Ø2 ½" drill bits get a little pricy, and Im assuming you dont have a press anyway (especially one with that big of a chuck), your best bet would be to find someone that does. If all else fails, take it to your local machine or metal shop and they'll probably do it for a fiver.
Offline paulstreats
  • Helpful? 20
« Reply #3 on: March 25, 2008, 05:53:51 PM »
it might be best to get it cnc'ed using a smaller bit, rather than trying to cut a single large hole like that through thin metal. The cnc will use a small bit, but cut out a circle with it - under computer control
Offline sdk32285
« Reply #4 on: March 26, 2008, 05:43:13 AM »
If you are at CMU there are 4 (maybe 5) machine shops on campus (RI,MechE,ChemE,Art)
Last post July 15, 2008, 12:51:21 PM
by Trumpkin
Last post November 13, 2009, 05:13:47 PM
by SmAsH
Last post August 23, 2012, 03:25:28 AM
Last post February 27, 2013, 10:27:15 AM
by SUTO the G
