Author Topic: Controlling of DC Motor with Robot Controller  (Read 1980 times)
Offline FionaTopic starter
« on: March 29, 2008, 09:44:58 AM »
Hi guys,
I'm trying to control the motion of my robot with a 2004 Mini Robot Controller (EDU-RC-2004). However, I wasn't able to change the motion of the DC motor. For example, when i wrote
/* Moving robot forward */
pwm01 = 20;
pwm02 = 250;
/* Stop robot  */
pwm01 = 127;
pwm02 = 127;
/* Moving robot backward */
pwm01 = 250;
pwm02 = 20;
The robot only execute the last motion which is to move backward.
Does anyone knows what is the problem? Thank You!
Re: Controlling of DC Motor with Robot Controller
« Reply #1 on: March 29, 2008, 09:50:17 AM »
Btw guys, I did insert a delay between each motion. It still doesn't work.  >:(
Offline Maltaeron
« Reply #2 on: March 29, 2008, 02:12:03 PM »
Are you using a DC motor or a modified servo?
If you are using a dc motor, you would have to reverse polarity in order to have a motor go backwards, and different PWM settings would only give different speeds.
If you are using a servo, make sure you have the PWM set up correctly and then it should work.
Good luck,
Offline michaelsane
« Reply #3 on: March 29, 2008, 03:40:17 PM »
Since you are using a FIRST controller I am wondering if you are using a victor speed controller, or is it a custom h-bridge?
« Reply #4 on: March 30, 2008, 10:55:59 AM »
http://www.ifirobotics.com/forum/viewtopic.php?t=66&sid=2ca42dbb1ceb536385bc087ca3757f9a
What do you mean?
Are you using a microcontroller? Are you sure that pwm01 is actually emitting a ~1.1ms pulse? Hook it up to an oscope, as I suspect the PWM you are using is meant for DC motors, and not for servo control like with your controller.
« Reply #5 on: March 31, 2008, 06:03:56 PM »
Hi guys,
pwm01 = 20;
pwm02 = 250;
/* Stop robot  */
pwm01 = 127;
pwm02 = 127;
pwm01 = 250;
pwm02 = 20;
very silly mistake
the same PWM must be sent a couple of times , not once
Last post September 09, 2007, 02:50:55 PM
by h3ro
Last post March 01, 2008, 10:56:44 PM
Last post May 06, 2008, 04:02:27 PM
Last post December 10, 2009, 03:38:03 PM
by definitionofis
