Author Topic: interrupts  (Read 1568 times)
Offline superchikuTopic starter
  • cooll
interrupts
« on: March 31, 2008, 01:40:23 PM »
hey all ,
i have made 3 bots so far but i have never used interrupts of any kind ,
i would like to know how would the interrupt be different from normal execution and how do they work also  i want to know that suppose iam using 3 adc channels so how do i  store the values from each channel after a conversion in different variables using interrupts using an atmega16
oh yes after storing the values, iam gonna use them for normal comparision and giving commands to my bot .
JAYDEEP ...
IT AND ROBOTICS ENGINEER
Re: interrupts
« Reply #1 on: April 06, 2008, 11:14:54 AM »
An interrupt is exactly that - an interrupt in your code to run other code.
So basically you set up an interrupt to trigger when an event occurs - such as a timer count (timer interrupt) or a digital port goes high (hardware interrupt).
When the interrupt is triggered it stops the code that is running, goes to run a special function you wrote, and when that function code is finished it goes back to the normal code.
  • cooll
Re: interrupts
« Reply #2 on: April 06, 2008, 11:23:08 AM »
that cleared my fundamentals thank u ..
JAYDEEP ...
Last post January 09, 2008, 01:43:31 PM
Last post June 22, 2008, 12:38:12 PM
by coldkryten
Last post October 04, 2008, 04:34:29 AM
by aruna1
Last post January 13, 2009, 03:21:01 PM
by TrickyNekro
