Author Topic: Delay Trouble  (Read 1784 times)
Offline michaelsaneTopic starter
Delay Trouble
« on: March 31, 2008, 05:33:32 PM »
I am working on a circuit board for my science fair project right now, and am having some trouble with c18 delays.  I can call the delay functions and the code compiles fine, but when I check the signal with my oscilloscope, the delays aren't the length they should be.  According to the datasheet for the 18f4320 (the chip i am using) each instruction cycle is 100ns, so If I delay 10 instruction cycles it should be 1 microsecond, but for some reason I suspect it has to do with the oscillator being improperly configured, but I have it set to HSPLL.  If anyone has any suggestions they would be greatly appreciated!
#include <p18f4320.h>
#include <delays.h>
#include <adc.h>
#pragma config OSC = HSPLL    /* Sets the oscillator mode to HSPLL */
#pragma config WDT = OFF   /* Turns the watchdog timer off */
#pragma config LVP = OFF   /* Turns low voltage programming off */
#pragma config DEBUG = OFF /* Compiles without extra debug code */
void MvServo (unsigned char, int);
void main (void)
LATB=0x00;
TRISB=0x00;
while(1)
MvServo(0xFF, 1);
void MvServo (unsigned char bports, int inst)
int i;
LATB=0x00;
TRISB=0x00;
for(i=0; i<100; i++)
LATB=bports;
Delay10TCYx(inst);
LATB=0x00;
Delay10TCYx(20-inst);
return;
  • Helpful? 107
Re: Delay Trouble
« Reply #1 on: March 31, 2008, 05:56:20 PM »
Don't forget that each line of C code may generate several machine language instructions - each of which may take 100ns. So your 'scope is probably correct.
Re: Delay Trouble
« Reply #2 on: March 31, 2008, 06:46:51 PM »
It was a bad oscillator.
Re: Delay Trouble
« Reply #3 on: March 31, 2008, 11:22:39 PM »
The bad oscillator was apparently only the beginning of my troubles... I can output near perfect 1 microsecond square waves, but when I set the delay any greater than 10 instructions it flips out.  For instance the code
void main (void)
LATB=0x00;
TRISB=0x00;
while(1)
LATBbits.LATB7=1;
Delay10TCYx(10);
LATBbits.LATB7=0;
Delay10TCYx(10);
The thing that perplexes me the most, is it appears to execute the code in the while loop only once, whereas with 10 instruction delay it loops infinitely.
Re: Delay Trouble
« Reply #4 on: April 01, 2008, 12:05:01 AM »
I kind of feel like a moron answering my own question, but when I set the OSC mode to HS instead of HSPLL it works just fine, so I guess it is just being unstable at 40mhz.
Last post April 04, 2008, 12:49:04 AM
by superchiku
delay
Started by ed1380 Electronics
Last post April 19, 2008, 07:37:57 AM
by benji
Last post August 10, 2008, 05:38:07 AM
by ert481
Last post July 09, 2009, 02:53:58 PM
by Luke
