Author Topic: $50 MOBOT and ERP  (Read 2968 times)
$50 MOBOT and ERP
« on: March 31, 2008, 09:14:27 PM »
What is that black material that is used for the base in the documentation of these two robots?
  • Helpful? 107
Re: $50 MOBOT and ERP
« Reply #1 on: March 31, 2008, 10:36:45 PM »
these two robots
Some kind of link would help. We know lots of robots  ;D
« Reply #2 on: April 01, 2008, 01:03:23 AM »
its on the SoR pages here under robots.
Offline cooldog
« Reply #3 on: April 02, 2008, 05:07:14 PM »
there ared 19 of them which one
these 2
http://www.societyofrobots.com/robot_ERP.shtml
http://www.societyofrobots.com/robot_mobot_2007.shtml
i thinks it's black HDPE (does it come im black?)
« Last Edit: April 02, 2008, 05:09:17 PM by cooldog »
-admin
favorite web sites
http://www.instructables.com/
« Reply #4 on: April 02, 2008, 06:04:02 PM »
I was thinking either carbon fiber or acrylic
« Reply #5 on: April 06, 2008, 10:44:41 AM »
I think its acrylic (or delrin?), I forgot what I used . . .
Its my new favorite material ;D
« Reply #6 on: April 06, 2008, 03:58:54 PM »
Why is it your new favorite matierial?
HDPE has so many good properties!
« Reply #7 on: April 06, 2008, 05:14:28 PM »
The best part of HDPE is its the easiest material to cut yet its still strong and lightweight and cheap.
However, the material is soft, scratches easily, and isn't that rigid. The translucent color also doesn't look as professional as a pure white or pure black color (like on my ERP).
Acrylic, nylon, and delrin have the advantages but not those disadvantages - but typically more expensive . . . Since money isn't a factor for me anymore, I no longer use HDPE . . .
Just search for those materials at mcmaster.com to compare - you may discover new options!
« Reply #8 on: April 06, 2008, 09:03:01 PM »
What kind of thickness do you recommend on acrylic/delrin?
I found this place in Southern California, in Anaheim right next to the Angel's stadium that offers will call pickup.
http://www.indplastic.com/
I just bought some HDPE there, very good service
« Last Edit: April 06, 2008, 09:06:20 PM by pomprocker »
« Reply #9 on: April 06, 2008, 09:18:49 PM »
1/6" is strong/rigid enough, but I often use 1/4" so I can tap it and put spacers and screws into it securely.
Oh, and its a bit heavier than HDPE, but I cut large holes into parts to reduce weight - like in the arms of my ERP.
« Reply #10 on: April 07, 2008, 03:31:33 PM »
How is the caster mount on these two robots constructed?
« Reply #11 on: April 07, 2008, 04:43:59 PM »
There are two flat plates with holes drilled halfway through the center of them. Then I used a .25" rod and placed it into both holes, with the rod also inside the caster wheel.
« Reply #12 on: April 11, 2008, 06:55:22 AM »
Ok I looked it up.
I am using delrin on my ERP. Its about twice as strong, twice as rigid, heavier, and about twice the price of HDPE. In fact, I used about $80 worth of delrin on my ERP (per version).
However, because its so much stronger, I can use my CNC and FEA to cut away large holes into all my parts to dramatically reduce weight without sacrificing strength. If I didn't have a CNC or money to spare, delrin would probably not be my new favorite material.
Last post August 31, 2006, 09:07:30 PM
Last post August 02, 2009, 03:36:48 AM
by gaurav.p
Last post April 10, 2010, 07:25:21 AM
mobot
Started by tonying Software
Last post March 01, 2013, 10:46:11 AM
by Azraels
