Author Topic: De-Soldering  (Read 4475 times)
Offline LefterisTopic starter
De-Soldering
« on: April 01, 2008, 01:21:46 AM »
Hello all,
continuing my experimenting in this new field I bought a cheap desoldering pump and went about trying to desolder. Contrary to the soldering process which was with the help of many videos/tutorials easy to comprehend I can't manage to desolder anything from an old no longer working obviously Graphics Card I found lying around my house.
     The components are soldered into the board so neatly (since it's done by a factory's robotic arm I guess) that I can't seem to melt the solder and suck it with the pump completely. Is there something I am missing? Maybe I am not supposed to try and desolder stuff from old graphics card or something? Or is the pump not a good way to desolder?
P.S: Also I noticed that it is quite hard to remove lumps of solder which have gone into the pump, after sucking, it was actually so hard that I thought I had broken the pump for a moment there  :P
Offline Trumpkin
Re: De-Soldering
« Reply #1 on: April 01, 2008, 08:04:21 AM »
I think most manufacturers put some kind of coating on the joints, making it hard to melt the solder.
Robots are awesome!
  • Helpful? 111
Re: De-Soldering
« Reply #2 on: April 01, 2008, 10:31:57 AM »
You can also try de-soldering braid which is lots of thin wires braided together. Put in on the joint and then the soldering iron on top. When the solder melts it is soaked into the braid. Obviously, unlike the pump, you can only use the braid once so its only worthwhile if the thing you are recovering is worth more than the braid.
Offline Gertlex
  • Helpful? 24
Re: De-Soldering
« Reply #3 on: April 01, 2008, 05:34:09 PM »
What parts are you trying to desolder from the graphics board?  Certainly really small parts, you just need tweezers or something to poke at the part as you loosen it's joints.
I
Offline HDL_CinC_Dragon
Re: De-Soldering
« Reply #4 on: April 01, 2008, 05:44:15 PM »
try adding solder to the joint before desoldering it... sometimes that helps. I do that more often than not
United States Marine Corps
Infantry
Returns to society: 2014JAN11
Re: De-Soldering
« Reply #5 on: April 01, 2008, 11:59:26 PM »
I tried desoldering some capacitors, since I thought they would be big enough to desolder easily. I did use a toothbrush and isopropylic alcohol too. Also added solder to the joint to make it easier to desolder. Nothing worked >_<.
   I guess I am not supposed to desolder stuff from another board or something. I hope if I make a mistake in soldering I don't get the same difficulties like this time  :P
Offline Trumpkin
Re: De-Soldering
« Reply #6 on: April 02, 2008, 08:04:37 AM »
You won't, It's easier with your own stuff.
Robots are awesome!
Offline pomprocker
Re: De-Soldering
« Reply #7 on: April 03, 2008, 05:46:55 PM »
You can pull the entire tip off the bulb.
Re: De-Soldering
« Reply #8 on: April 03, 2008, 09:40:30 PM »
Yeah? Oh thanks, I would not have tried that alone since I am afraid of handling these new for me tools. Now I will try it :)
In other news my first soldering got ... well ... messy. Except from the last 6 pins I could not seem to be able to apply the solder to only one hole ... it went to other holes some times forming connections which were not supposed to exist! :(
I think I need a smaller solder tip, and I also think I need new male header pins and a new IC socket :P since I screwed up ... I will try de-soldering the whole thing, but maybe buying new stuff and starting again would be wiser since I kind of melted the plastic from the male header pins .... exposed it for too much time to the iron's heat I presume.
« Last Edit: April 03, 2008, 09:42:59 PM by Lefteris »
Re: De-Soldering
« Reply #9 on: April 03, 2008, 09:46:54 PM »
practice makes pefect
also, always buy like 5 more parts then you need when dealing with connectors and sockets ( inexpensive parts)
its always good to have extras
  • Helpful? 111
Re: De-Soldering
« Reply #10 on: April 03, 2008, 11:20:42 PM »
My first attempt was using an old 25 Watt iron with a 'traditional' tip. I managed to keep burning the copper caps off the perf board and blobbing solder everywhere.
Am now having a lot more success with an 18Watt iron with the 'needle like' tip.
Offline pomprocker
Re: De-Soldering
« Reply #11 on: April 04, 2008, 01:23:03 AM »
you want like a 40 watt iron. there is a really good soldering video posted on this forum somewhere see if you can find it and watch it.
Offline pomprocker
Re: De-Soldering
« Reply #12 on: April 04, 2008, 01:24:36 AM »
Offline paulstreats
Re: De-Soldering
« Reply #13 on: April 04, 2008, 05:22:33 AM »
If its just a cheap soldering iron, you will need to keep unplugging it regularly otherwise it will get too hot, I suspect this is why the solder pads are coming off the per board
Re: De-Soldering
« Reply #14 on: April 04, 2008, 06:33:53 AM »
Thanks for the replies people ! :)
As for the soldering iron it is a 40W Weller, I was told it is an okay soldering iron for start
Offline Trumpkin
Re: De-Soldering
« Reply #15 on: April 04, 2008, 07:14:52 AM »
Also, if you desolder a lot on one copper pad it seems like it comes off.
Robots are awesome!
Re: De-Soldering
« Reply #16 on: April 04, 2008, 02:35:46 PM »
Well I managed to make the whole circuit shown in the tutorial, now I only need to adjust it to add the H-bridge to control the 2 DC motors. But now I'll stop since the fumes from the solder made me feel funny  :P
By the way does anyone know if the 2 wires from each DC motor matter? I mean is one '+' and one '-' ? Does it matter? Since I the motors I found in the toy RC car, don't have anything engraved on them.
Re: De-Soldering
« Reply #17 on: April 04, 2008, 02:43:14 PM »
all you have to do,  is that if one motor is turning in the wrong direction , just flip the wires of the motor
search google on how DC motors work for more info
Offline pomprocker
Re: De-Soldering
« Reply #18 on: April 05, 2008, 02:31:31 AM »
Left... Read the motor tutorial on this website.
Re: De-Soldering
« Reply #19 on: April 06, 2008, 03:51:51 PM »
no.
but the motor will spin a certain direction depending on which way you wire them up
Infantry
