Author Topic: Saw this cheap perforated board  (Read 2343 times)
Offline airman00Topic starter
« on: April 03, 2008, 06:48:50 PM »
http://www.allelectronics.com/cgi-bin/item/ECS-1/455/SOLDERABLE_PERF_BOARD,_1_HOLE_PAD_.html
I'm thinking about getting that and cutting it in half. Its pretty big too , at approx. 6" by 4"
Would it shatter or somehow get screwed up if I cut it?
Offline goatfish
Re: Saw this cheap perforated board
« Reply #1 on: April 03, 2008, 07:26:10 PM »
that could be pretty easy to snap,but if ii snaps  kinda where u want it you could then file it down tough work i know,but its worth a try ;D
Offline ed1380
« Reply #2 on: April 03, 2008, 07:58:01 PM »
if you cut it with a fine blade it'll be ok. like a hacksaw or a steaknife
Offline michaelsane
« Reply #3 on: April 03, 2008, 08:09:45 PM »
They should have some cheaper stuff than that.  Last time i went to their store (in person) I found some perfboard that size for about $1.30
Offline lkik
« Reply #4 on: April 03, 2008, 11:57:24 PM »
could use a band saw if you had acces to 1
« Reply #5 on: April 06, 2008, 03:29:48 PM »
I use a bandsaw to cut boards like that all the time.
You could also use a mill, scroll saw, or a dremel with the right attachment.
Oh, and don't breath in the dust. ;)
« Reply #6 on: April 06, 2008, 03:59:20 PM »
oh man  ::)
lol jk
thanks for the advice , but I ended up buying a bunch of perf boards on eBay for cheap .They dont need any cutting .
