Author Topic: AVR resetting on its own problem  (Read 4536 times)
Offline AdminTopic starter
« on: April 04, 2008, 01:53:35 PM »
I have an AVR that keeps resetting and I don't know why. The time between resets is sometimes predictable, sometimes not (usually every 1-4 seconds). Sometimes it never resets. Sometimes I feel as if hitting the boards in just the right way might cause a reset, but not sure and its not consistent.
I have several boards made exactly the same, all with the same code, all with the same problem. The time to reset isn't consistent among each board.
The power supply is loaded with caps and a voltage regulator. The oscope says there is no power fluctuation at any time. The two major power draws on the board are just two LED's.
Between resets, everything works properly. That means voltages everywhere are correct.
What I've done to debug, but to no effect:
- I tried both an external crystal and an internal oscillator.
- Tried several batteries, all fully charged
- Tried several battery connector cables
- checked and rechecked soldering on all boards
- Tried several oscillator frequencies
- Turned off the LED's in code
- removed the on/off button
- used a 50x microscope to look for shorts between pins, found none
The last thing I can think of to do is remove the onboard CP2102 usb adaptor, but wanted other ideas first . . .
Offline superchiku
  • cooll
Re: AVR resetting on its own problem
« Reply #1 on: April 04, 2008, 02:18:13 PM »
isnt it a coincidence iam also getting the same problem , my servo which iam controlling continously vibrates, may be due to resetting from left to right and right to left instead of taking full sweeps , may be there are power fluctuations , otherwise the mcu wont reset
JAYDEEP ...
IT AND ROBOTICS ENGINEER
Offline hgordon
  • Helpful? 7
« Reply #2 on: April 04, 2008, 02:18:59 PM »
Do you have a pull-up (or pull-down) resistor on the reset line, or is there just a power-up reset circuit ?  I've seen similar problems on processor cards that were designed assuming a pull-up wasn't required, but that was a bad assumption.
Surveyor Corporation
  www.surveyor.com
Offline superchiku
  • cooll
« Reply #3 on: April 04, 2008, 02:28:15 PM »
i thought that a mcu can resetted by applying the gnd voltage to the reset pin, how do pull up registers help in resetting?
JAYDEEP ...
« Reply #4 on: April 04, 2008, 02:35:34 PM »
hmmmm I just assumed it wouldn't need one . . . so I don't have one there . . . but . . .
I just took a jumper cable and attached reset to ground, and the board stopped running (as its supposed to do).
Then I forced it to 5V, and the reset problem just continued like 'normal' . . .
The problem also occurs regardless of whether the programmer is attached or not.
So nope, thats not the problem unfortunately . . .
superchiku, a pull-up resistor prevents a floating voltage from causing it to reset on its own
Offline benji
« Reply #5 on: April 04, 2008, 02:42:45 PM »
1/try changing the code , totally, make another simple code and run it, this way you know its not your code making the problem
(i suppose there are bits in registers that may cause a reset condition(interrupt))
2/take the mcu out of the board and put it in a test board,run it and see if it resets there.
good ol' BeNNy
Offline vidam
  • Robotronics.org
« Reply #6 on: April 04, 2008, 02:44:58 PM »
Maybe you set brown-out detection too high (4.3 V). So when the voltage to your AVR goes below a setpoint (i.e. fuse setting) the MCU resets?
[BEGIN EDIT]
I just re-read your post. I see you check the voltages already to make sure they are constant at 5 V.
[END EDIT]
« Last Edit: April 04, 2008, 03:07:39 PM by vidam »
Offline dunk
« Reply #7 on: April 04, 2008, 04:18:12 PM »
you don't have WDT fuse bit enabled by mistake?
Offline superchiku
  • cooll
« Reply #8 on: April 05, 2008, 03:24:08 AM »
Does that fuse matter ???
JAYDEEP ...
Offline paulstreats
  • Helpful? 20
« Reply #9 on: April 05, 2008, 06:24:35 AM »
yes. It is designed to reset the mcu when the watch dog timer overflows. unless the wdt is perodically set at 0x00 in code then it will overflow and reset the mcu.
Offline superchiku
  • cooll
« Reply #10 on: April 05, 2008, 07:34:31 AM »
oh.. that cleared my fundamentals..
JAYDEEP ...
Offline JesseWelling
  • Only You Can Build A Robot!
« Reply #11 on: April 05, 2008, 11:41:56 AM »
Sounds like a Null pointer problem or a jump of the end of an array problem.
Offline TrickyNekro
  • 1.6L Peugeot 307 tuner
« Reply #12 on: April 05, 2008, 05:35:57 PM »
Did you check the noise levels in the area?
I knew some guy how even shielded his AVR for EMI caused by a motor or a relay... (I don't get to remember but it was an elevator project)
Also adding a pull up surely helps a lot...
Cheers!
Lefteris
Cheers!
« Reply #13 on: April 06, 2008, 07:36:38 PM »
I've run more experiments and it gets weirder. I'll explain that first, then address everyone's comments.
For some strange reason, if I send long data streams *into* the Rx port on my microcontroller, it causes a reset! A short datastream of just a few characters doesn't cause the reset.
During all my tests I've used the UART to detect resets. The status LED (programmed to turn on during power up) flickers a bit during resets, but its really hard to see.
I'm already running simplified code . . .
Oops forgot to mention that I already tried all the brown-out fuses, and I even disabled them. This was my first thought too!
its a surface mount, no can do :P
Nope its not enabled. If it was the WDT, it would be predictable . . .
this happens in very simple loops, such as:
while(1)
rprintf("output %d",output);
Now considering I'm starting to strongly believe it has something to do with uart, there is always the possiblity there is a problem with AVRlib - especially since I had to modify it to handle 4 uarts! I've uploaded the source if anyone is willing to look over it. The folks over at avrfreaks.net constantly rant at how the uart code for avrlib is terribly outdated.
I'll run another test tomorrow that doesn't use rprintf or uart, and I'll scope a digital output pin to hopefully detect resets.
I have no motors or other noisy components connected.
Offline CuriousInventor.com
« Reply #14 on: April 06, 2008, 10:04:00 PM »
Did you try bypassing the voltage regulator and powering the circuit directly with 5V?  Also, do you have .1uF ceramic caps going to ground at every power input to the chip?
-Scott
forgot you already looked at the power on the scope and saw no variation... still might be worth a try
« Last Edit: April 06, 2008, 10:29:00 PM by CuriousInventor.com »
Offline frank26080115
« Reply #15 on: April 06, 2008, 10:08:05 PM »
Clock source fuse bits, if they are wrong, you will have predictable resets as you described
« Reply #16 on: April 06, 2008, 11:21:30 PM »
I would say check out their buffer implementation.
Also this looks suspicious if you are indeed using 4 uarts:
volatile u08   uartReadyTx[2];
volatile u08   uartBufferedTx[2];
// receive and transmit buffers
cBuffer uartRxBuffer[2];
cBuffer uartTxBuffer[2];
unsigned short uartRxOverflow[2];
// Omited for clarity
volatile static voidFuncPtru08 UartRxFunc[2];
As you can see the arrays are declared of size two and in other function like the init and what not they are referenced by index of 2 and 3. So I'd increase that to 4 if you are going to use all 4.
For example this function if called would access off the end of the arrays declared above:
void uart2Init(void)
// initialize the buffers
uart2InitBuffers();
// initialize user receive handlers
UartRxFunc[2] = 0;
// enable RxD/TxD and interrupts
outb(UCSR2B, BV(RXCIE)|BV(TXCIE)|BV(RXEN)|BV(TXEN));
// set default baud rate
uartSetBaudRate(2, UART2_DEFAULT_BAUD_RATE);
// initialize states
uartReadyTx[2] = TRUE;
uartBufferedTx[2] = FALSE;
// clear overflow count
uartRxOverflow[2] = 0;
// enable interrupts
sei();
« Last Edit: April 06, 2008, 11:24:24 PM by JesseWelling »
« Reply #17 on: April 07, 2008, 07:50:20 AM »
You see Jesse, this is why I gave you green robots next to your name!!!
Problem solved!
(I never knew accessing data outside of an array could cause a hardware reset . . .)
I'd been struggling with this 8 hrs/day for the last 4 days . . . I'd kiss you if it wasn't highly inappropriate! :-*
Just for fun I added ceramic caps and various resistor types across the voltage reg output, but it didn't solve this problem.
« Reply #18 on: April 07, 2008, 05:44:42 PM »
Hmmmm so the problem is still here, albeit a lot more rare now. :-\
Its no longer random, and now very predictable. Its this problem I mentioned earlier:
It still appears to be an improper access of memory, because sometimes it appears to jump in code - including to functions in my code thats never used! The compiler seems to be compiling unused code :-\ . . . It doesn't matter if its a long stream or short.
It occurs in this while loop:
rprintfInit(uart3SendByte);//define uart port
while(1)
temp=uart0GetByte();//returns -1 if no data present, takes data from uart port 0
//&0x0F strips ascii off to use in char strings
  if (temp != -1)//if data received
rprintf("%c",temp&0x0F);//transmit to uart port 3
It waits for data, and whenever data is received, the reset happens. If no data received, no reset.
Also, in uart.h, I found another code error, but fixing it didn't solve the problem:
// define this key if you wish to use
// external RAM for the UART buffers
//#define UART_BUFFER_EXTERNAL_RAM
#ifdef UART_BUFFER_EXTERNAL_RAM
// absolute address of uart0 buffers
#define UART0_TX_BUFFER_ADDR 0x1000
#define UART0_RX_BUFFER_ADDR 0x1100
// absolute address of uart1 buffers
#define UART1_TX_BUFFER_ADDR 0x1200
#define UART1_RX_BUFFER_ADDR 0x1300
// absolute address of uart2 buffers
#define UART2_TX_BUFFER_ADDR 0x1400
#define UART2_RX_BUFFER_ADDR 0x1500
// absolute address of uart3 buffers
#define UART3_TX_BUFFER_ADDR 0x1600
#define UART3_RX_BUFFER_ADDR 0x1700
#endif
« Reply #19 on: April 07, 2008, 06:39:39 PM »
Hold on I'm being stupid.
I changed uart4.c and uart4.h in the wrong project folder!
I'll retry this sometime later tonight . . . ignore my last post for now.
« Reply #20 on: April 07, 2008, 06:59:45 PM »
Ok problem solved, no more resetting :)
I really need to keep my common files straight on all my bots . . .
« Reply #21 on: April 07, 2008, 08:36:12 PM »
Version control works great for that. CVS or SVN. At work we have one 'project' but 4 microcontrolers with about 75% common code.
You might think about setting up a Source Forge Project for SOR, it would help this kind of problem and also let people like me contribute in the familiar open source way... just a thought.
Offline JonHylands
« Reply #22 on: April 08, 2008, 05:37:57 AM »
Yeah, having fully switched from PICs to AVRs, I am using my brother's repository (http://svn.hylands.org) organization for all my projects now. All the common files are shared...
- Jon
  • Helpful? 107
« Reply #23 on: April 08, 2008, 05:57:48 AM »
I've moved away from copying the .h and .c files from one project to another as it gets confusing, for a new project, which project you should copy the files from. Especially if you modify some of the clock specific stuff.  Version control is one solution. Another is to have a project for all your utilities and then compile them into a new library rather than an elf. In your projects you can then add the new library onto the search path without copying files around at all. The only consideration with the library approach is if you are using lots of different mcus and/or different clock rates in which case you may generate different libraries for Mega8-1Mhz and Mega8-8Mhz etc and then its just a matter of changing the library search path to include the correct library.
Offline benji
« Reply #24 on: April 09, 2008, 03:15:18 AM »
how is it you are accessing data outside an array in your code?
the copiler always turns the c code into assembly before generating macine language so you can always check the assembled code
and see what causes the reset,, maybe its a compiler issue
good ol' BeNNy
« Reply #25 on: April 09, 2008, 06:40:58 AM »
Because he told it to  ;)
volatile u08   uartReadyTx[2];See the size of the array? means it's two elements big. So that means the compiler makes room and you can access  uartReadyTx[0] or uartReadyTx[1] But he Told it to access further down the array, which is nonexistent:
uartReadyTx[2] = TRUE;This might or might not cause a reset, it all depends on what you just overwrote. One scenario is if it happened to be a pointer to a function that just got set to 'TRUE' your code is going to bonkers after that and eventually reset depending on the rampage path it takes through crazy land.
Offline benji
« Reply #26 on: April 09, 2008, 09:34:24 AM »
thanks Jesse for makin this clear
good ol' BeNNy
Last post May 03, 2009, 12:01:39 PM
Last post September 03, 2009, 09:21:45 AM
by airman00
Last post October 03, 2009, 11:02:45 AM
by ukesh
Last post April 16, 2010, 08:33:28 PM
