Author Topic: AVR assembly question  (Read 1604 times)
Offline benjiTopic starter
« on: April 06, 2008, 09:50:42 AM »
im doing some avr assembly coding for interfacing an optical mouse sensor
i chose assembly simply because i want to know whats going on every single cycle.
in the atmega8 datasheet it says you can use the R registers , R0 >>>> R32
while using R0>>R15 it doesnt recognize it, so im using R16 >>>R32
why is that?
also in the datasheet when examples are provided they are using R16 and not R0
there should be a reason for that? any idea?
another question about avr studio 4
when i press the build button it doesnt build it and it writes (error excuting)
i changed the code and still the same
then i wrote one operation in the code and the same happened  :-\
help
good ol' BeNNy
Re: AVR assembly question
« Reply #1 on: April 06, 2008, 11:49:25 AM »
Stupid check: When you start a project in AVR Studio, you have to tell it to use the Assembler and not the GNU compiler . . .
Offline izua
« Reply #2 on: April 06, 2008, 12:40:02 PM »
registers 0 to 15 have a few limitations to the operations that can be performed on them.
you can't use ldi for example
« Reply #3 on: April 06, 2008, 03:48:46 PM »
,, im using the assembler  ,,Stupid  ;D
thanks for the info,, is this mentioned somewhere in the datasheet?
good ol' BeNNy
Offline izua
« Reply #4 on: April 06, 2008, 05:29:29 PM »
i'm not sure.
it's because of the instruction size, they had to crunch in many instructions, a tradeoff for parameter size
check out this tutorial for more info: http://www.avr-asm-tutorial.net/avr_en/beginner/REGISTER.html#Unterschied
Last post January 07, 2009, 01:44:02 PM
by dsPICgy
Last post January 24, 2009, 11:13:19 AM
by frodo
Last post May 14, 2009, 01:35:44 PM
by LunchBox!
Last post June 04, 2009, 06:40:28 PM
