Author Topic: Modified Servo to rotate angles  (Read 1854 times)
Offline harisankarsaTopic starter
« on: April 07, 2008, 11:28:58 PM »
Can we use modified servo to rotate to some angles like non modified ones....
Offline Rebelgium
Re: Modified Servo to rotate angles
« Reply #1 on: April 08, 2008, 09:58:17 AM »
by modifying you remove the potentiometer, which means it can't "see" where it's turned... so no.
orgcrime.net
« Reply #2 on: April 12, 2008, 06:52:45 AM »
You can if you add an encoder to the output shaft - you can make your own or buy one (a bit expensive) for servos.
Last post September 29, 2007, 06:24:02 PM
by creedcradle
Last post September 16, 2011, 07:45:54 AM
by jml
Last post December 13, 2008, 04:32:36 PM
by airman00
Last post September 13, 2011, 06:41:45 PM
by knossos
