Author Topic: $50 Robot SharpIR/photovore algorithm  (Read 2265 times)
« on: April 08, 2008, 03:20:15 PM »
I have built the $50 robot with the photosensors and programmed it to be a photovore.
Then I upgraded it with the Sharp IR and programmed it to scan.
Now it does'nt utilize the photosensors anymore.
So I am trying to figure out a good algorithm in some pseudo-code that I can implement.
I want object avoidance, with light sensing to help tell if its too bright for the scanner to work efficiently
or if a scan finds nothing to resort to being a photovore while still scanning
something like that, I guess i'm going through ways in my head to make these two senses work together.
Robot gets closer and closer to object
   Is the object very bright?
      It could be a white wall!
         Avoid the wall!
Robot can not find any object with scanner
   Check light sensors
      Is robot in direct sunlight?
           Move to darker area so scanner works better.
Offline superchiku
  • cooll
Re: $50 Robot SharpIR/photovore algorithm
« Reply #1 on: April 10, 2008, 11:59:39 PM »
well it is quite simple actually to do obstacle avoidance and simultaneosly follow use the sharp ir ,
have u seen any sumo bot competition , ull see that the bots will normally avoid the white boundary linw ans also seek out the other robot, now how u do that??
when the sharp ir  is scanning and getting data, call for another adc conversion for the ir leds. now do a decision according to the data found , suppose any of the ir sensors get a data which means that u have to avoid something then stop all other functions of the robot and keep turning the robot away from the obstacle for 3 or 4 secs which will be sufficient for obstacle avoidance, aafter obstacle has been avoided continue with ur scanning session and do whatever ur robot is meant to do..
JAYDEEP ...
IT AND ROBOTICS ENGINEER
Last post September 20, 2009, 07:12:16 PM
Last post June 27, 2010, 03:33:17 PM
by matz91
Last post July 06, 2010, 07:33:58 AM
by Selenaut-14
Last post March 06, 2013, 01:02:45 AM
by newInRobotics
