Author Topic: phototransistor/motor driver circuit  (Read 2549 times)
Offline WaldoDTDTopic starter
« on: April 09, 2008, 04:42:37 PM »
Ok, so I am trying to create a transistor switching circuit so that when i put voltage on the base pin of a Bipolar junction transistor (NPN) it will turn on a motor current. After much frustration the circuit doesn't work. I have the motor wired from the emitter pin to the ground and +9 VDC on the collector. My microcontroller pulls the base pin to 5VDC. Should I use a opto isolator? Or should I rethink the transistor circuit? Thanks!-Waldo
Offline brijesh
Re: phototransistor/motor driver circuit
« Reply #1 on: April 09, 2008, 09:59:18 PM »
Whipped up this one just now. Let me know if you problem with this one.
There is wide leeway for resistor values. R1 should be greater than 10*R2. And R2 should be such that when enable signal is asserted enough current flows through base-emitter diode to turn on the transistor. In the current case with 5 volt signal about 5mA flows, which should be enough to turn on the transistor.
« Reply #2 on: April 14, 2008, 06:56:33 PM »
Last post July 10, 2008, 09:39:10 PM
by Webbot
Last post February 07, 2009, 07:36:22 AM
Last post February 10, 2009, 07:43:41 PM
by Canabots
Last post December 12, 2012, 07:03:47 PM
by jwatte
