Author Topic: Paralax Cont. Rotation Servo  (Read 2424 times)
Offline killstoTopic starter
« on: April 10, 2008, 04:07:50 PM »
Well I just broke my servo. Tried to get look in the back and snapped the (pcb?) in half. Doesn't really bother me. I now have a potentiometer to use if I ever need one. I found this premodified servo and I was wondering if it is any good? It's only $4 more than the HS-311. Is that a good site from which to buy? I understand Parallax makes reliable, if occasionally  overpriced, easy to use products.
« Last Edit: April 10, 2008, 06:44:28 PM by killsto »
Offline 555 timer chip guy
Re: Paralax Cont. Rotation Servo
« Reply #1 on: April 16, 2008, 12:10:29 PM »
you don't need to tack off the PCB to modify a servo you gust disconnect the pot from the gear train.
« Reply #2 on: April 16, 2008, 12:11:47 PM »
actually that is the lazy way of doing it. But it works for me.
Offline GHF
« Reply #3 on: April 18, 2008, 07:45:53 PM »
The Parallax servo is pretty good if you're lazy and don't want to modify servos yourself, especially if you need to use 4 or 6 on a robot. Adjusting them is a real snap compared to the regular kind, since the pot is accessible without opening the case, and so you can use it with a micro (exactly 1500us center) or a RC set (which usually have a center off of 1500us for some reason).
The actual mechanicals of the servo are nothing out of the ordinary.
The connector is an "universal" type, but the output shaft is Futaba-style (it's made by Futaba), so it won't fit into Hitec-style servo horns/wheels.
However, like modified servos, the pot adjustment does drift a little if your bot goes through a rough trip to a competition or something. Like normal motors though, you can fix that with a bit of hot glue.
I'd recommend them just because they're easy to adjust. I hate having to take a servo apart after it's mounted on the inside of a robot.
-Xo W.
Offline BANE
  • E=roboticsC^2
« Reply #4 on: April 20, 2008, 05:59:15 AM »
hey lynxmotion now offers continous rotation servos :D  I got some about a week ago and there much better than parallax servos.  and for only $12.99
http://www.lynxmotion.com/Product.aspx?productID=429&CategoryID=38
Bane
Last post March 18, 2007, 11:40:56 AM
Last post July 13, 2007, 11:13:55 AM
Last post September 01, 2008, 04:30:10 PM
Last post October 04, 2009, 06:41:08 PM
by blackbeard
