Author Topic: $50 robot bootloader error  (Read 3004 times)
« on: April 12, 2008, 07:35:46 PM »
I am getting this:
>fboot17.exe -b57600 -c3 -p50_robot_sharpIR.hex -v50_robot_sharpIR.hex
COM 3 at 57600 Baud: Connected
Bootloader V1.7
Target: 1E9307 ATmega8
Buffer: 960 Byte
Size available: 7680 Byte
File 50_robot_sharpIR.hex open failed !
Program-Error
I have followed the instructions on the website here, went through em twice.
I have the hex file in the proper folder.
Re: $50 robot bootloader error
« Reply #1 on: April 13, 2008, 07:56:42 PM »
I changed the hex filename to ranger.hex and it worked. I bet its 8 characters or less for the filename.
« Reply #2 on: April 14, 2008, 01:17:17 AM »
I've found that I can only program the robot once using fboot.exe. The second time around it won't even connect.
Its like it over writes the boot loader section of flash.
I have looked at the ATmega8 Datasheet and on page 212 it talks about BootLocks. I have programmed BootLock11 which is suppose to block SPM from being able to write to the bootloader flash.
That still didnt work. I think its still over writing the bootloader flash.
« Reply #3 on: April 15, 2008, 10:08:56 AM »
ok Disregard that last post. I had the USB breakout board powered up wrong.
« Reply #4 on: April 24, 2008, 06:37:41 PM »
funny thing, I recently had the exact same problems as you, and solved them in the same way :P
(Ill update the bootloader tutorial when I have time to address these issues)
Last post April 15, 2009, 08:06:56 PM
by klims
Last post August 12, 2010, 07:03:56 PM
Last post May 17, 2009, 04:47:17 PM
by catalinene33
Last post January 09, 2011, 06:56:50 PM
by Joker94
