Author Topic: Building a remote control Sofa/chair  (Read 2619 times)
Offline ussfletcherTopic starter
« on: April 12, 2008, 11:58:49 PM »
To begin I would appreciate any help in regards to parts that I should use, as well as tips.
My project: Turn a couch or chair into a ridable vehicle
The basics are I would like it to be able to move about 500lbs (in the case of the sofa) at roughly 10-25mph
Currently I'm considering using car batteries, a transmitter, a receiver and H-bridges.. are there any other electronics I would need? Also Any help that could be provided for motors that would be powerful enough would be greatly appreciated.
Re: Building a remote control Sofa/chair
« Reply #1 on: April 13, 2008, 04:57:42 AM »
hmmmm
im thinking 4x4 drive using wheelchair motors
« Reply #2 on: April 13, 2008, 01:38:29 PM »
Thats sort of something I was considering. Would two wheelchair motors be enough to power that you think? I've used deWalt drill motors on a 120lb robot which was able to move around a 180lb man sitting on it, so would there be any smaller motors that would be able to do the job (cost is sort of an issue looking for it to be <$500)
« Reply #3 on: April 13, 2008, 03:26:33 PM »
yea two wheelchair motors would probably be fine also
get high power 24V ones
Offline ALZ
« Reply #4 on: April 14, 2008, 01:04:02 AM »
You would have to use some very big tires to be able to go 25 mph !
hmmmm
Offline cooldog
« Reply #5 on: April 14, 2008, 03:57:25 AM »
i saw a guy on discovery channel that did this only not remote control. also there is a world recored for this under worlds fastest furniture. so look around and see what others have done
-admin
favorite web sites
http://www.instructables.com/
« Reply #6 on: April 14, 2008, 04:34:41 AM »
yep you are right , I forgot about the 25mph part
If you want 25mph why not just stick on a gas engine ?
« Reply #7 on: April 14, 2008, 05:39:26 PM »
I was trying to stay away from gas engines due to noise and exhaust issues, as well as cost but maybe I'll look into it a bit more.
Offline AndrewM
« Reply #8 on: April 14, 2008, 08:52:07 PM »
Don't forget about the heat of a gas engine on a wood and cloth frame.  Need to add plenty of heat insulation or you might get the record for the world's fastest fireball...
blog: www.iamwhen.com
Saving the world from humanity one robot at a time.
« Reply #9 on: April 14, 2008, 09:38:09 PM »
there has to be some DC motor out there
keep looking
« Reply #10 on: April 26, 2008, 04:22:37 PM »
This will help you calculate what motor will be sufficient for your robot:
http://www.societyofrobots.com/robot_faq.shtml#select_motor
Last post April 22, 2007, 04:50:57 AM
by jschoormans
Last post July 08, 2007, 09:26:49 AM
by megaman935
Last post May 03, 2008, 12:09:28 PM
Last post March 05, 2012, 11:39:55 PM
by robotcoder
