Author Topic: IR camera  (Read 2256 times)
Offline dcole07Topic starter
IR camera
« on: April 17, 2008, 02:29:32 PM »
I would like to use a IR camera with a robot, but they seam to be hard to find. Can you guys name any sites that sell them?
The wii remote is a good example of technology that uses an IR camera. I know IR sensors can't hard to find, but these just pickup the general amount of light in the area (1 value).
Thanks.
Re: IR camera
« Reply #1 on: April 17, 2008, 03:03:23 PM »
almost all webcams can see IR light
maybe use roborealm and filter out all colors except for the color of IR light thats picked up by the camera
Offline hgordon
  • Helpful? 7
Re: IR camera
« Reply #2 on: April 17, 2008, 03:55:51 PM »
http://www.drsinfrared.com/
Entry level cameras such as DRS E3500S cost $6k
Surveyor Corporation
  www.surveyor.com
Offline Steel_monkey
Re: IR camera
« Reply #3 on: April 17, 2008, 04:30:04 PM »
Just specify wavelength of interest. If below 1 mkm, everything is OK. If above it, no hobby-level cameras available. IR LED wavelength is in average 0.85 mkm.
Offline maverick monk
Re: IR camera
« Reply #4 on: April 17, 2008, 04:33:04 PM »
http://www.superdroidrobots.com/shop/item.asp?itemid=837&catid=37
analog, but probobly usable
http://www.superdroidrobots.com/shop/item.asp?itemid=769&catid=64
digital, ip camera? why...
this is analog + digital it seems, but is color camera, if used in conjunction with an IR emitter, will it pick it up and return in b+w???
http://www.superdroidrobots.com/shop/item.asp?itemid=736&catid=37
« Last Edit: April 17, 2008, 04:38:00 PM by maverick monk »
Offline frank26080115
Re: IR camera
« Reply #5 on: April 17, 2008, 04:42:53 PM »
most low cost cameras with those adjustable lenses will have an infrared filter, remove it, then buy a cheap TV remote and remove the visible light filter from the front and use it to replace the IR filter you removed.
Offline d13
Re: IR camera
« Reply #6 on: April 17, 2008, 07:10:37 PM »
This may not be what you need, but the wii remote detects up to 4 points.  This guy is using them and gives some examples of how he is doing it:
http://www.cs.cmu.edu/~johnny/projects/wii/
Offline BANE
  • E=roboticsC^2
Re: IR camera
« Reply #7 on: April 20, 2008, 06:01:49 AM »
What about hacking an old camcorder that IR on it?
Bane
Last post June 03, 2009, 06:03:20 AM
by SmAsH
Last post May 30, 2009, 08:15:04 PM
by galannthegreat
Last post December 15, 2009, 04:07:03 PM
by andreiipascalin
Last post January 24, 2010, 11:51:18 PM
by bsamuels
