Author Topic: Where should I look for these part?  (Read 2958 times)
Offline videorovTopic starter
« on: April 17, 2008, 10:25:40 PM »
Im looking for a camera I can pan left and right and maybe up and down some.
I would like to be able to pan up to 180 degrees left and same to the right.
I don't need to pass through the 180 degree point.
Im also looking for a clear plexiglass round container in a tube shape. Maybe 4" diamater and
maybe 4" tall. I will cap the ends with plexiglass aswell while building project.
Im building a underwater camera system and want to be able to pan around and up and down.
Any help for the parts would be great.
Offline Ro-Bot-X
  • Helpful? 25
  • Store: RoBotXDesigns.ca
Re: Where should I look for these part?
« Reply #2 on: April 18, 2008, 06:13:51 AM »
make your own pan/tilt mechanism
or buy one from servocity.com
Offline pomprocker
« Reply #3 on: April 18, 2008, 11:28:05 AM »
yes servocity.com has a $48 pan and tilt mount.
Also you can probably get that acrylic tube from McMaster.com
« Reply #4 on: April 18, 2008, 09:12:45 PM »
What would be the best way to glue acylic and be waterproof?
« Reply #5 on: April 18, 2008, 09:36:41 PM »
The Logictech would be nice but USB doesn't work over long distance Ive found. Ive used USB
booster cables on some usb cameras and the problem is the power to the camera doesn't seem to
go to far. If you put a hub which has power to it then the camera will stay on. I think the usb signal
make it but not the low voltage.
Ive been using regular video board cameras and they seem to work fine at 100ft with 12volts.
I wonder if Cat5 cable could carry the usb signal and power to the camera 100ft?
Offline AndrewM
« Reply #6 on: April 18, 2008, 10:57:32 PM »
Use a welding type cement. http://www.google.com/search?hl=en&q=%2Bacrylic+%2Bweld
blog: www.iamwhen.com
Saving the world from humanity one robot at a time.
Offline Ro-Bot-X
  • Helpful? 25
« Reply #7 on: April 19, 2008, 06:53:14 AM »
I just replyed to you other post, so you probably know the hub ideea (as videorov also sugested) . Thinking about the Cat5 cable, I think it is a little stiff. If you don't need to tether the sub, use a more flexible cable. A 2 wire shielded audio cable would be much better, since you don't need to transfer power for the USB, just ground (shield) and the 2 signal lines. If you do need to tether the sub, try to use more of the shielded audio cables. You may want to find a larger sleeve and pull it over the audio cables to keep them together, or just tape them together from place to place.
« Reply #8 on: April 25, 2008, 01:24:57 PM »
I made my own pan/tilt camera mount for my ERP:
http://www.societyofrobots.com/robot_ERP.shtml
Offline superchiku
  • cooll
« Reply #9 on: April 25, 2008, 01:33:31 PM »
How did you install a cnc in your house arent these machines supposed to be costly???
JAYDEEP ...
IT AND ROBOTICS ENGINEER
« Reply #10 on: April 25, 2008, 01:38:18 PM »
doesnt have to be in your house per say , could be for a business
most construction companies have a  CNC machine , maybe a local one can help you out
« Reply #11 on: April 25, 2008, 01:50:43 PM »
I have access to the CNC through my job.
Offline superchiku
  • cooll
« Reply #12 on: April 25, 2008, 11:44:29 PM »
thats cool , it would be like so easy to cut out your parts using cnc
JAYDEEP ...
