Author Topic: Charging / Docking Station  (Read 2872 times)
Offline RobertoTopic starter
  • My iPhone 3G
« on: April 18, 2008, 08:07:08 PM »
Hey,
  I was using my Sonicare toothbrush the other day, and when I put it in the charger, I noticed how there is no connection to the battery, and somehow charges the battery through the case. ??? I started thinking of a charging station that the robot goes to and is charged by backing up into the station. If anyone knows if I could use a charging technique similar to the toothbrush, please respond.
If you need to email me:
[email protected]
Please no spam!
Thanks,
Anton (a.k.a Roberto)
« Last Edit: April 18, 2008, 08:32:14 PM by Roberto »
Vote for Roberto The All in One Robot in the 3rd SoR robot contest!
societyofrobots.com/member_tutorials/node/143
Offline AndrewM
Re: Charging / Docking Station
« Reply #1 on: April 18, 2008, 10:40:14 PM »
If I had to guess without taking one apart, the charging station on the sonic care uses a transformer based charging unit.  The base is one big loop of wire with current running through it, the handle has another loop of wire.  The current passing through the base loop generates an EMF field.  The handle loop picks up the EMF field which gets turned back into current, and viola touchless charging.
blog: www.iamwhen.com
Offline Rebelgium
« Reply #2 on: April 19, 2008, 06:13:09 AM »
If there is no electrical contact, like the TS said, this is indeed the only way this is possible.
But this is not applicable to robots...
weighs to much, and the robot would have to be very close to the charger or else the efficience will be ridicoulous.
orgcrime.net
  • My iPhone 3G
« Reply #3 on: April 19, 2008, 08:06:20 AM »
Thanks anyway. Hopefully someday I will figure out a way it can work for robots.
Thanks again,
Roberto
Offline paulstreats
« Reply #4 on: April 19, 2008, 10:16:28 AM »
That is indeed how they work, the base unit has the primary coil with an iron core, the iron core protudes from the base unit but is covered with plastic, the toothbrush usually slots over the iron core where there is the secondary coil. Because they us the iron core (regardless of the plastic coating) they get a much more efficient power transfer
« Reply #5 on: April 25, 2008, 11:54:11 AM »
This site is both informative and amusing for wireless recharging:
http://www.afrotechmods.com/cheap/arnoldpad/arnoldpad.htm
Offline pomprocker
  • Helpful? 16
« Reply #6 on: April 25, 2008, 12:00:13 PM »
hahahaha
[img width= height=]http://www.afrotechmods.com/cheap/arnoldpad/babes.jpg[/img]
Offline pomprocker
  • Helpful? 16
« Reply #7 on: December 10, 2008, 09:55:19 PM »
I took apart my sonicare advantage tonight following the instructable.
http://www.instructables.com/id/Repairing-your-Sonicare/
I guess the batteries are dead. says expired 04 02
They are two AA NiCD cells, I assume they can be replaced with AA NiMH cells?
